Question about Whirlpool LSQ8000 Top Load Washer
Nail protruding into inner basket from outside
I need to remove the inner basket in order to remove the nail. I know how to remove the agitator. What are the steps to remove the inner basket?
It's a Sears Kenmore Clothes Washer model 110.26 26442 500
Thanks!
  • Anonymous Mar 21, 2014
    i need to know what size basket is in a kenmore model 110.20022013
    President:
  • 2,976 Answers
Hold the basket and remove the nut in the center. It's reverse thread.
Posted on Jul 01, 2009
How do you clean the lint filter?
you can't clean lint filter. It has a built in filter that cleans itself. It is under the inner basket. If you have to, than remove the agitator and inner basket. It is attached to basket on bottom. No need to clean though
If you need further help, I’m available over the phone at https://www.6ya.com/expert/keith_6cb11225ab437567
Jun 15, 2014 | Whirlpool Ultimate Care II LSQ9564J Top...
Suspect we have a finishing nail under the agitator...how do we remove the agitator? model KAWS750LT1 I know how to get the fabric softener dispenser off
To remove the softner dispenser just grasp the outsides of it and pull up,or wiggle it side to side.It fits into the agitator by pressure and has no clips or screws.
If you dont find the nail there under the agiator the inner tub would need to to removed to see if it's in the outer tub. To remove the inner tub a special tool is needed.
Gene
Aug 20, 2011 | KitchenAid Washing Machines
I dropped nails in the washing machine tub and they fell through the holes. Will this damage the washer if I run it, or might the nails just go out the drain? So far, I have been unable to remove the...
The inner basket may be also bolted to the transmission. If left in there, they will end up in the pump. If this is a steel tub machine, you can buy a good sized magnet, and leave it in the wash basket, near the problem area. The nails should collect on the other side, and hopefully keep them from spreading significant harm, until you can get them out of there. You may be able to **** them out with a good strong shop vac.
Jun 21, 2010 | GE Washing Machines
Whirlpool top loader washing machine needs clutch
also check drive block for the inner basket to make sure it is ok.drive block is under the agitator.remove agitator with 7/16 socket.
Mar 03, 2010 | Washing Machines
Clothes stuck inbetween basket on Maytag Bravos washer
This is for several brands ... not just the Bravos.
Based on your description, it looked like you needed to take the center agitator out first .... to then access the inner basket bolts ... remove the inner basket to then get to where the clothes are ... not a real easy task
capture-ce5c5tqeeiqfekdpzmvievq3-1-0_0.png Good luck on your troubleshooting
Jan 25, 2018 | Maytag Bravos 3.8 Cu. Ft. Washer
I want to know how to remove the inner drum on my Samsung top loader to enable me to clean the outer drum.
you will need to remove the agitator by removing 1/4"hex screw at the bottom of agitator,then you need a "spanner wrench" to remove inner tub-basket hold-down nut then you can remove inner tub to clean outer tub
Nov 18, 2009 | Admiral AW22 Top Load Washer
My washer agitator spins but the tub doesn't,also see metal insid
Repair or replace is always a judgement call. Most people will be better off replacing the machine. This is a rather big job, labor wise. On a difficulty scale of 1 -10, I'd give it an 8. The metal is the inner area between the inner drum and the transmission shaft, which has corroded and started to break apart. (located under the agitator) To repair, the agitator is removed, the washer front and top are removed to allow the washer's outer tub cover to be removed. This allows the inner tub to be removed. (caution: the big nut under the agitator drive spline is a left hand thread) Then, the drain hose, water level hose, suspension rods, and electrical to the motor are all removed to allow the entire drum to be removed from the washer to allow the inner tub to be removed. The actual metal part which needs to be replaced is then easy to replace by removing a few torx head screws from the underside of the inner tub.
Oct 02, 2009 | GE Profile WPSR3120WWW
Maytag mav6200aww removing inner tub
I broke a hammer removing the basket on a 6000 series today. These are known to be a real ***** to remove. Once those screws are out there is a seal nut to remove and the basket hub assembly is what it sits on. Look at 5 and 7 below.
Jul 29, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Model 80 Sears Kenmore washine(Remove inner basket)
under the agitator youll see a lock nut appox 2-3in, around "locking" the inner basket to the outer basket. although they do sell a spanner wrench to remove this nut, A decent pipewrench and little muscle will get it loose, after that the tub will pull right out. assuming youve taken off the outer tub gasket cover
Mar 09, 2008 | Washing Machines
Whirlpool LSQ8000 Top Load Washer Logo
178 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
