Question about Hoover Washing Machines
My Hoover washing machine 800RL spin cycle is slow leaving the clothes driping wet
Check and see if the bowl spins as fast as the agitator (hold a screwdriver in the lid limit switch to bypass) You may also notice clothes are severely knotted. If the bowl is slow and agitator fast then ther is a problem with the gearbox. If you know how to fix this, or remove the gearbox, please let me know.
Posted on May 06, 2010
  • Cliff Zimmermann Aug 09, 2013
    Helpful for initial diagnosis. Also monitor drain rate by watching water after using screwdriver in the lid limit switch.
I have had this problem before and found that it was actually clothes stuck in between the inner and outer bowls after somebody overloaded the washing machine. To get at it you need to remove the back and then the top. You then unclip the plastic "lid" on the bowl and you can get access to inside.
Posted on Mar 07, 2010
  • 1,056 Answers
Check first if there is anything binding in the pump. turn the washer on its side and remove the pump connected to the motor with two long clips. when the motor is removed it can be checked for debris that might have caused the binding. If there was a lodged clothing in there removing them sometimes restore normal operation. if not the motor might have gone bad from overloading caused by this debris., and needs replacing. cost of a new motor usually 75- to a little over a hundred dollars
Posted on Jul 01, 2009
    The intake to the pump was clogged by small plastic parts from kid's toys. Thanks for the helpful advice!!
Hoover 800rl wont spin
sounds like an issue with the progrmmer if it does everything else, or there may be an issue which a sensor has caught that causes it to desist from spinning. Probably needs a repairman to diagnose..
Jun 03, 2015 | Hoover Washing Machines
Washing machine 11 years old is jumping on the wash cycles. EG instead of taking 25 mins its taking 10 mins to complete -clothes coming out wet unless manually turn to spin again
It is possible that the program is not running to the designed settings and so the program seems to skip the cycle.
The clothes come out wet because the spin cycle is not activated in the set program. Hence the program controller needs a check.
Jan 17, 2011 | Hoover Washing Machines
Clothes still driping water after spin cycle
Remove pump motor and check for any obstruction internally. If clear, blow into each end of both pipes and inspect for blockages. That will be the area or the problem.
May 18, 2010 | Washing Machines
Clothes still wet after wool cycle
Hi
For all washing machines irrespective of the make... Wollens and acryllic do NOT have a spin cycle as the same will damage the clothes....
In wollen and acryllic mode the machind is NOT supposed to go into a spin cycle and hence you get wet clothes.....
There is Nothing wrong with your machine.
Regards
Berry
Jan 31, 2010 | Washing Machines
Ca230 w. machine not spinning leaving clothe wet, no water in drm
It is possible that the belt at the back of the machine is slipping. try running the spin cycle without any load in the machine. I assume this is a front loading machine and you are in UK. the Belt is available on line for about 15 pounds.
If it is running the washing cycles normally, it can't be the motor.
Dec 06, 2017 | GE S8000E
Hoover 200m Top Loading Machine Spin Cycle Too short
no not normal many different things can be wrong need more info
May 08, 2008 | Hoover HTC243 Top Load Washer
Series 70 kenmore elite washing machine
If it goes through the complete cycle o.k. except for the slow spin then the motor itself needs to be checked.
Mar 20, 2008 | Kenmore 24622 Top Load Washer
Washer not spinning right and not completing a cycle
Sounds like you need to replace the carbon brushes on your washing machine motor
Sep 26, 2006 | Hoover H130E Front Load Washer
Washing Machines Logo
645 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
