Question about Orion Televison & Video
Orion vcr vr0418 won't get incoming cable channels
Orion vr0418 won't get incoming cable channels
3 Suggested Answers
ladywinn
  • 5138 Answers
SOURCE: orion tv codes
call 1-800-274-8995 maybe this will help! 1-800-347-3288
Posted on Nov 30, 2007
SOURCE: my sanyo vcr model vwm 690 won t run auto setup when connected to
the sanyo 690 is the best vcr out I have had mine for 10-12 yrs!
just make sure you are in the vcr mode and not tv or cable mode it will do everthing for you!!!!!! columbo
Posted on Jan 25, 2011
Cannot get video on my Orion model VRO 211B
Could be a connection problem. Pins on plugs can become bent or damaged, sometimes it is the socket that the plug fits into that becomes damaged. Try a different connection lead.
Dec 26, 2015 | Orion VR0211B Video Cassette Recorder...
I have a Goldstar VCR and I want to record a tv program using it. How do I do it?
Most Goldstar VCRs only have an analog tuner. (TVs do not often have an option to output their video to another device.)
So first what is the source of the TV program? If it is an OTA analog or CATV cable. Set up the VCR normally by connecting the incoming signal cable to the VCR and then use the coax out to the TV. Scan for channels and set the VCR to record the desired program. (Either use the timed record or one touch record method.)
If your source is digital, you will need a set top box (either a digital to analog converter or cable box). To split an incoming OTA signal between your TV and the converter box, you can use a switch or a splitter. (A splitter will give lower signal strength to both the TV and the converter box.)
Depending on the box, you can either connect a coax cable from the box to the VCR and then to the TV or composite video from the box to the VCR. If you use coax, set the converter to channel 3 or channel 4 and record that channel. Otherwise set the VCR to record Line 1.
To record, put in a tape with sufficient space available with an intact safety tab. For One Touch Recording, set the VCR to the desired channel and tape speed. Then press Rec. Press several time for a timed recording. For Timed recording, press Menu > Program. Press Select and move through the list to program day to record, the start/stop time, and channel, etc. When done, press Menu to save the setting. The timer light should come on (most VCRs will turn off).
I hope this helps.
Aug 05, 2011 | Goldstar GBV241 DVD Player/VCR
Orion tv codes
Hello
Try with these codes
Four digit universal codes for Orion are
0121 0135 0035
Three digit universal codes for Orion are
035/ 121/ 135
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Nov 19, 2010 | Televison & Video
How do I hook up a VCR? There is only a portal for the cabel on the back. mpartridge
You will need to have a VCR with a cable connection on it. You will need to remove the cable connection(if connected) on the TV and connect it to the "cable in" connection on the VCR. Then the coaxiel cable will connect from the "cable out" connection to the cable connection on the television. You will then need to turn the channel on the TV either to channel 3 or 4. Then turn on the VCR and you should be able to watch a tape on the VCR. If your VCR does not have a cable connection on it then you will need to buy an adapter that turns the cable connector into RCA style jacks.
Jan 12, 2010 | Orion1934 19" TV
I cannot get vcr to record channels timer goes on and on playback blue screen
I assume it plays back a pre-recorded film with no problem? Check your antenna is connected to the input of the VCR or your cable box. If you have a cable box connected via a scart connector, then select AV channel on the VCR & select the programme from the cable box. If you are using the antenna the go into the set up menu & retune the VCR into your incoming channels & ensure the flylead from the output of the VCR (at the rear of the video next to where the antenna cable is positioned) is connected to the input antenna socket of the TV.
Jul 28, 2009 | RCA Televison & Video
Orion VCR 213 will not record with converter box
The chain of cabling that you have should go like this; First in line should be the wall supplying the cable box. Then, the cable box connects to the VCR, then the out of the VCR should go to the TV. Select whatever channel you desire, make sure that the VCR is on Channel 3 or 4, (Whichever the back of the cable box is set) then select 3,4 or line/AUX to see the results....accordianman
Dec 12, 2008 | Orion VR213 VHS VCR
Just want the Orion TV (Model: STV 2763) to play VHS videos
Problem Solved:
Take your connector with the 3 colors red,white & yellow and plug into VCR OUT. The other end (w/ 3 plugs) goes into the INPUT on the back of the TV. Next insert a VHS Tape & search the TV for input or a channel below #2 for Cable#1,2,3 or AUV Channel.
In this case; Channel AUX #1
Shows / Plays Video w/ clear sound & picture.
Yahoo.
May 21, 2008 | Orion STV2763 27" TV
Help me fix my orion tv problem
Let it run an autoscan or see if in the menu it has channels that are blocked or disabled.
Nov 26, 2007 | Orion STV2763 27" TV
Orion vcr model vr313
You need not set your VCR to either CHs 3 or 4.  You simply have to set it to the channel that you would want to record. Further, the coax either from your cable or aerial should go straight to the VCR for it to receive any of the channels. The VCR then maybe hooked up to your TV either buy a shorter cable and this is when you set the TV to either 3 or 4. Alternately, you can use the RCA connector from your VCR to your TV.
This is a generic/compressed solution. Pls post back should you want additional information.
Good luck and kind regards.
Oct 23, 2007 | Televison & Video
How to set clock on Orion VCR VR0419
Most late VCRs require the remote box to set the clock, timed recording etc. Assuming you have the Orion remote, it should have a programming or menu button, and the function you need can be selected from a list of options. If the remote is an aftermarket unit (non-Orion), it must have the capability to do the advanced setup (clock set etc.). Many aftermarket remotes only do basic channel selection, and tape functions (play, rewind, stop, etc.).
Apr 24, 2007 | Orion VR0419 VHS VCR
Televison & Video Logo
47 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
