Question about Directed Electronics D2205 Car Amp
D2205 wont turn on
I had a green power light but a blinking ESP light for a long time. as of yesterday it just quit. I checked all physical connections and fuses
I have a 56 in hdtv Panasonic tv will not come on green light flashes 20 times then goes to red. Help, on disability fixed income & cant afford to get repair or new tv. Please help, as soon as poss
Panasonic Plasma TV Repair - Understanding 14 Blink ...
? 8:35
https://www.youtube.com/watch?v=iHBIiRxhe0w
Sep 26, 2014 - Uploaded by ShopJimmy.com
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. ...tv to come on bcause the power button keep blinking my tv will not come on.
Nov 06, 2015 | Panasonic Televison & Video
Replaced bulb yesterday worked fine. Today light will not turn on. projector turns on both lights green for 10 seconds, then power goes red and status blinks green for about 5 seconds, then status light...
green green is power on, normal
then it tries to light the lamp, but it can't so the protection circuit comes activated.
you get red and green blinking
Then it goes to standby, red and off.
so something has happened to the lamp, or lamp ballast power supply.
Take the lamp out and check if all is OK with the 2 terminals in the connector, and the leads to the lamp are intact.
Failing that, I would suspect the ballast lamp power unit
Mar 25, 2011 | Mitsubishi HC1600 Projector
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Yesterday i changed the lamp. After this I turned the TV on and it worked fine. This morning, upon turning it on,it showed for a few minutes and then the screen went blank, the green power light started to...
how many times is the red led blinking? if you just changed the lamp make sure and check that the lamp door is secure if the door is ajar it will flash 3 times.
Dec 22, 2010 | Sony Grand WEGA KDF-50WE655 50" Rear...
The power outage went out yesterday and my tv wont turn on
Most likely it is capacitors on the dm board that have gone bad. This is a fairly common problem and has been addressed on fixya many times. If you know someone who is good with soldering and technically incline or even an honest electronics guy then the repair is quite cheap. If you have any other questions please let me know. if its not the capacitors on the DM supply then its a problem with the whole DM assembly that part usually is around 300$. So you may want to consider purchasing a new tv. Trying the 7 caps on the dm supply board shouldn't cost much if it takes anything more then that. I would sell the tv on craigslist or ebay and recoup as much as you can towards your next tv.
thank you,
lee
Thank you,
lee
Apr 01, 2010 | Mitsubishi WS-55511 55" Rear Projection...
The tv wont turn on
hello 2 blinks on this tv means you have this issue below
PT-44LCX65
2 blinks 5 secs you have your lamp cover open
check for this
hope this helps
Dec 14, 2008 | Panasonic PT-44LCX65 Television
New Bulb Doesn't Light
color wheel or light engine,call for service and save your money.
Aug 04, 2008 | Samsung HLN467W 46" Rear Projection HDTV
Philips 42PF7320A blinks 3 times every time i hit the power button
The SSB is small self contained board that u connect your Antenna, and HDMI to. An error three is a communication error between the SSB and to Logic board ( located underneath the SSB on the back fo the plasma panel that is just below the power supply. U can check parts.com and see if u want to purchase a SSB for this TV. Is the 3blinking lights coming from the front of the TV. Also check the power supply and see how many times the green led blinks on the upper left of the power supply and let me know.
Apr 24, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Directed Electronics D2205 Car Amp Logo
55 people viewed this question
Top Directed Electronics Car Audio & Video Experts
xxxxxx xxx
Are you a Directed Electronics Car Audio and Video Expert? Answer questions, earn points and help others
