Question about Fellowes SB85C Shredder
Runs, then full light comes on
When turned on it has a green light for about 8 seconds, then the bin full light comes on. While the green light is on it works fine (about one sheet).
Do you think the "full" sensor is dead, broken,burned out?
where can I buy one of these sensors to fix it?
  • buckvarjassy Dec 07, 2007
    Hi, I am having the exact same problem with my SB-87Cs. It may not be the exat same model but the pics look identical. Any help here would be greatly appreciated, this is just so frusterating.
    Thanks in advance!
  • Anonymous Dec 09, 2007
    I have the same problem with my SB-85C. I researched it a while ago.
    You can try cleaning the transmit and receive glass "eyes" located behind
    the plastic swiveling plate that hangs down near where the paper exits.
    When working properly, the paper fills and pushes against the plastic plate
    which swivels and cuts the infrared or laser beam between the glass eyes.
    If dirty, the beam will become very sensitive and trip prematurely.
    My problem is more severe. Cleaning no longer helps. There is an FAQ at
    Fellows website that allows you to submit a request to the servicing group.
    I just submitted a request for a replacement paper full sensor. I'm not sure if
    they will send me one or not. I really don't want to have to pay to ship the
    unit and have it serviced.
An update ... SB-85C with the same problem.
Called customer service and they were very helpful. They will need all of the information that is on the tag on the bottom of the power head. It will then cost you a little less than 10 bucks - including postage - for the new sensors.
Also ask them to email you the "Instructions for PC Board Replacement: SB-80, SB-85C, SB15C, & SB-87Cs". It is a four page color PDF that gives all the details any "handyman\mechanic" would need to get it apart without breaking anything important.
Posted on Jul 19, 2010
To follow up my 12/9/2007 post, Fellows got back to me. I emailed
them the serial number and some other info and they sent me a
replacement wire harness with 2 new sensors attached, free
of charge. The replacement process was straightforward but
not trivial. If you work on cars or are comfortable taking things
apart and reassembling, you should have no problems.
The gear assembly needs to be lifted in order to replace the old wire
harness. It is heavy and greasy. Don't get grease on new sensors.
I had to cut a couple of tie wraps holding the old harness in
place. I did not have tie wraps to replace them, so I used twist
ties from a box of plastic bags.
I am delighted with Fellows for taking care of this for free without
forcing me to ship the shredder someplace for servicing.
Posted on Jan 08, 2008
I emptied the shredder and now the red overheat/door open light comes on when I turn it on. will not allow me to shred anything. please help!
There is an interlock that prevents your shredder from operating without the bin in place. Something may be stuck inside, preventing the bin from closing the interlock. There also could be a shred of paper preventing operation.
Feb 17, 2015 | Compucessory CCS60076 - High Security...
Scotsman cme 1656 bill full stay on after cleaning
Ok did you damage the bin thermostat cap tube? The bin thermostat is what tells the unit the bin is full if so replace it.
Nov 14, 2013 | Scotsman CSW45 15" Ice Maker with 26 lb....
Runs about 60 feet and quits. no click from the solenoid. wait a couple days and it will repeat same problem. It is an old model but was never used. I bought it from teacher who prefers her scooter
Unfortunatly, it sounds like your batteries will not take a full charge need to be replaced.
The batteries contain a gel that needs to have current run through it on a regular basis (at least 8 hours once a week) or it will solidify. If you attach the charger, what will most likely happen is the green light will either stay green or go to green after a very short time. The charger will indicate the batteries are full, but instead of being full of pwer, they are full of crud. Since you are the second owner, the repairs are up to you. You can probably find compatible replacement batteries from Interstate Batteries, Batteries Plus or Battery Warehouse. Good luck!
Oct 22, 2010 | Pride Jazzy 1650 Heavy Duty Power...
I have a 1998 NWH10 Toyota Prius. My problem on Start up.
Have both your battery and alternator inspected. Turn it on, disconnect your negative battery cable, if it dies, you need an alternator, if not, then you may want to test your battery for bad cells.
Feb 16, 2010 | Toyota Prius Cars & Trucks
The basket full light will not go out
Sep 15, 2009 | Fellowes DM15C Shredder
Bin Full light stays on all the time
This is usually an indication that the photo eyes are probably dirty. They "See" across the opening where the ice drops through. If they are dirty, it registers as a fill machine.
A bin stat can cause the same problem.
The eyes and sometimes be a major problem finding them getting to them. On smaller machines like this one, it's hard to get your hands on them.
Good Luck and hope this helps.
Jan 08, 2009 | Scotsman Freezer Clear Icemaker w/ Pump
Keeps going black and coming back on - green light blinks
Our tv is about 2 1/2 yrs old and did the same thing we had to replace the bulb and bulb driver board this fixed the problem
Jan 27, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Fellowes SB85C Shredder Logo
455 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
