Question about Samsung Refrigerators
My refrigerator is liking water - Samsung Refrigerators
  • Samsung Master
  • 3,267 Answers
The heater in the blower assembly must not be working, thus allowing water vapor to condense as Ice, which melts and also the condensation of water on the inside surface of the fridge keeps flowing down & out. Get the blower & heater working by repair/replacement as the case may be.......................sodeep
Posted on Jul 01, 2009
I have a GE Profile Performace Refrigerator and the water dispenser and Ice maker are not getting any water. No water is coming into the refrigerator. Water line to refigerator is working. What may
Check the water solonoid on the lower right side facing the rear of the unit. the water line connects to it. sounds like it might be defective.
Apr 07, 2012 | GE Refrigerators
Water dispenser drips on my Samsung side by side. Not much, suspect limescale but unable to access to clean up. Any ideas?
That really has to be bothersome! I can imagine a leaking roof and pails and buckets everywhere tying to collect the water. On your refrigerator the problem could be related to a defective water control valve, air in the water lines like after adding a new filter and having to purge the air out before the water flows freely. You mentioned lime as a element in your water supply and sounds like you may have well water. Lowes or Home Depot see nice in-line water filter to pre-filter the water before getting to your refrigerator. As for the water control valve tat may be stuck open like a dripping faucet, it may need replaced. Try to see if turning the water supply off to refrigerator before refrigerator and see if water continues to drip. If yes then I belie a new dual water control valve will be needed. Let me know what happens and do get a pre-filter they are really helpful, Sea Breeze
May 23, 2010 | Samsung RS2630SH Side by Side Refrigerator
Water is gathering in the bottom of my Siemens KG32U123GB fridge
Water created during the refrigerator defrost cycle drains into a catch basin (usually located behind the back interior panel of the refrigerator). This catch basin normally has a tube attached to it that carries this water to a pan located underneath the refrigerator. When the water reaches this pan, it is evaporated by heat from the compressor and refrigerant coils.
There is likely a blockage in this drainage system in your refrigerator. Looking at the back, you likely will see a tube exiting the back of the unit. If you can easily do it, pull off this tube and blow into it. If the tube is open, the blockage is likely in the catch basin. This is not good. To get this opened up, you will have to remove the back panel of the refrigerator.
Oct 18, 2009 | Refrigerators
Whirlpool Custom Series refrigerator leaks -Model ET18JKXSN05
It sounds like the line you found is for draining the water from the defrost cycle. It should drain the water from melting the ice into the pan at the bottom so it will evaporate. Sounds like its being clogged is the cause of the water in your fridge.
May 13, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
My refrigerator water dispener is dispensing jelly like stuff !
run it until the water comes out clear and replace the filter trice.
Mar 30, 2009 | Maytag MSD2756G Side by Side Refrigerator
Would like to install a water filter
Add a in-line filter to the incoming water line behind the refrigerator.
Most have 1/4 inch compression fittings to adapt.
Mar 05, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Water smells/tastes like freon
freon has no smell or taste and in any case doesn't get anywhere near the water. look elsewhere like your water supply
Nov 04, 2008 | Kenmore 53463 Stainless Steel Side by Side...
Problem with water flow in LG LRBC22544 Bottom Freezer Refrigerator
Sounds like you have excess pressure building up in the water system. Is the water dispensor working? If not it sounds like you have a frozen line somewhere or the valve in the door is not working to allow the water to dispence.
Jul 13, 2007 | LG LRBC22544 Bottom Freezer Refrigerator
Refrigerators Logo
101 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
