Question about Lasko High Velocity Space-Saving Blower Fan HVB - 4924
Not blowing enough air
It is not blowing enough air like it used to is there filters i need to change if so how do i open the fan body to chang them
  • 90 Answers
The back top of the fan pry open.
then you will see screws
Posted on Aug 01, 2009
Air conditioner is blowing cool air but not hard enough. changed the filter but it was very dirty.
may need the evaporator coil cleaned and blower which also may be plugged up with dirt.Also may have weak capacitor or fan motor.
Aug 23, 2011 | Comfort Products Heating & Cooling
2004 dodge 1500 cabin air filter
the cabin air filter is located on the passenger side of the cowl. after opening the hood, remove the windshield wipers and the black covering ( 2 small T-30 screws, and a few body grommets). after you remove the cowl there will be a grey accordion looking filter in the cowl, remove that and replace with the new filter.
Apr 18, 2011 | 2004 Dodge Ram 1500
What parts do i needed for a tune up on a kia 2004 saoda
write down the manufacture date the vin number engine type and capacity eg1.5,1.8,2.0 armed with this info head down to your parts shop you will need. oil correct grade for your car 5litres will be more than enough or just right for 4 cyl. oil filter spark plugs some cars use irridium or platinum with some cars these do have standard equivilant that are cheeper fuel filter air filter a can of throttle body cleaner to clean the throttle body jack up the car sit it on stands never trust a jack remove the drain plug from the sump drain the oil into suitable dish or container and dispose of it responsibly replace the sump plug and tighten it firm locate and remove oil filter fit new filter spin it on then tighten by hand half a turn locate and change fuel filter dont forget to inspect filters for leaks when service is finished add new oil to correct level start engine run til oil light has gone out swich off recheck oil level remove spark plug leads mark them or do one at atime change spark plug put leads back on open air box remove old filter loosen clamp on air intake where it fits on to engine at throttle body move out of the way hold butterfly open and spray with cleaner to remove built up deposits a small bottle brush is good to get inside refit the air intake pipe and filter the cleaner will make the engine run a bit rough you may have to wind it a bit to start it it will clear itself after running for a short time be shaw to refit any plugs or connectors and pipes
Apr 06, 2011 | 2004 Kia Sedona
It's not blowing enough cool air out. It sometimes accumulates ice behind the filter.
seems like its clogged up and needs a good cleaning. fan could be all dusty, etc
Jul 09, 2009 | Heating & Cooling
Central air conditoner unit doesnt blow cool air into home has some ice on the inlet heat and cooling lines going into the central air unit
Change the furnace filter. Make sure you use a cheap one when air conditioning, as the better ones restrict airflow when they filter out so much stuff and then plug up, not allowing enough air to pass over the cooling coil in the furnace's air plenum. Turn the A/C off for a few hours (with only the furnace fan on if possible) to melt the ice off the cooling unit inside the furnace.
Sep 01, 2008 | Carrier Heating & Cooling
Levelling Driver's Door and replacing air conditioner filter behind glove compartment
Regarding the door, you are prob going to need a body repair shop to do it properly.
The cabin ir filter is located behind the glovebox. Open the glovebox, remove all of your personal stuff. Disconnnect the shock absorber-looking thingy at the right side. Press IN on both sides of the glovebox "box", to defeat the 2 travel limiting pins on either side. The cabin air filter is located in a black or white rectangular looking door, pull it out and extract the filter.
Jun 16, 2008 | 2004 Toyota Avalon
PC SUDDENLY SROPS
I think your system may be heated check out your processors temperature, if it is very hot change your cpu fan.
Feb 22, 2008 | EliteGroup P4VMM2 Motherboard
Lasko High Velocity Space-Saving Blower Fan HVB - 4924 Logo
934 people viewed this question
Top Lasko Dryers Experts
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
