We are only using cold water every time..
SOURCE: hoover washing machine top load, model 550m.5.5kg
water leak from cold hose nothing to do with other problem. tighten hose connection and fit a new hose washer overfilling probably because air chamber blocked. remove lid. you will see a pressurestat somewhere at the top - usually round with anything from 3 to 7 wires and a small tube underneath. follow hose down and it connects to the air chamber. make sure this is free of gung and check hose for splits and has no blockage. to check the pressure stat itself, attach your own hose to the stat and while machine in fill mode, blow down this hose and you should hear a click and water intake will stop
SOURCE: GE Washing machine cold water barely dribbles in
well the first thing i would do is take the cold line loose from the washer get a large bucket and open the cold line with the hose off and see what kind of pressure there is if very little need a plumber or in crese your well pump pressure check your screen while you have the hose off if all of this is ok id replace the washer water valves
SOURCE: roper washing machine mod# RAS8245EQ1
The problem is one of two parts. One is your water temperature switch or your hot water solinoid. To get to the back you must remove the hex screws on the back and then the panel is removeable.
SOURCE: Kenmore Washing Machine - no cold water coming in
most likely cuase would be the inlet valve
you would need the complete model number to make sure you get the right part for that unit.
SOURCE: washing machine
-the conditioner compartment may be blocked
- the cable with spring that change course of the water may be out,
