Bars treatment is for a temporary fix and like everything temporary it will fail when you want it most. Holes in the cooling system no matter how small will stop the pressure build up that raises the boiling point of water . Water under pressure takes in more heat so the engine runs cooler That is why you have a pressure rated radiator cap. I would recommend a compression test to check for head gasket problem. Have a flow test done on the radiator to check for blocked cores. make sure that there is not an air lock in the cooling system
SOURCE: ford fiesta radiator cap.... where is it?
the radiator expansion tank will be located in the top left or right corner of the bonnet bay and should have a yellow cap.
please rate this advice.
