Cameras Logo
Darleen Getz-gauthier Posted on Aug 16, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kodax easyshare z612 battery died, didnt use my camera for along time, now i have no pics and i only can take 2 pics then my internal memory is full. cant transfer cause there is nothing to transfer.
Stan Ford
Level 3:
Genius:
  • Kodak Master 3,131 Answers
  • Posted on Aug 16, 2014
Stan Ford
Kodak Master
Level 3:
Genius:
Answers
3131
Questions
Helped
905582
Points
9078
The external memory card is missing or faulty. Its a good idea to save your pics. to a cd or hard drive.
5 Related Answers
A
Anonymous
  • Posted on Oct 28, 2007
SOURCE: Transferring from internal memory to memory card
connect camera to computer without disk. Go to "my computer", click on the camera icon, it should say how many pictures you have and ask what you want to do with them.
Anonymous
  • 44 Answers
  • Posted on Nov 16, 2008
SOURCE: transfer pics from internal memory to Sims card
when reviewing pictures on the internal memory push the menu button. There is an option to copy the pictures to the memory card.
Anonymous
  • 34 Answers
  • Posted on Jun 22, 2009
SOURCE: Trying to transfer pics on internal memory to my SD card.
Set the image storage setting of the camera to Internal.
Once it is set to internal, put the card in the camera and press review.
Copy the pictures from the internal memory to the card.
Anonymous
  • 11967 Answers
  • Posted on Jan 21, 2011
SOURCE: I have a Kodak Easyshare C195 digital camera my
There should be an entry for "copy" in the camera menu.
Andy
  • 262 Answers
  • Posted on Feb 23, 2011
SOURCE: I have not been able
The problem is that your camera is only compatible with SD cards, not SDHC cards. You bought a larger card for your older camera, not noticing that it was SDHC (or not knowing that it mattered). The new card can't be formatted, not because it or the camera is broken, but because it's not compatible.
Cards up to 2Gb are generally SD.
Cards of 4Gb are generally SDHC.
Cards over 8Gb have to be SDHC.
(There are exceptions. Sometimes, manufacturers make 4Gb SDHC cards but some have errors; they disable half of the chip and sell it as 2Gb, but it's still SDHC. 4Gb cards are almost always SDHC because they're cheaper, but 4Gb SD cards do exist. They are so rare that I've even seen a guru on this site claim they don't. I did own one once, but it was very expensive and turned out to be so unreliable that I had to return it. I don't recommend looking for one, because of the problems.)
Your solution is to go find a 2Gb card, and be extra sure that it doesn't say "SDHC" on it.
Internal memory full ?
buy a memory card or delete the internal memory to make room for new pictures
I have a kodak easy share camera M340 and I can't take any photos since it says Internal memory is full. Help
Buy yourself an SD memory card and transfer your pics to the card. That will clear your internal memory. You can save all your pics that you take from now on in the SD card.
How do I switch frm using the internal memory to the memory card? My Z612 is apparently not reading the memory card. When I turn the camera on I get a message that says "internal memory is full."
Download the pics you want to save from the internal memory. Then, with no card in the camera, go into the menu and find "format"...follow the on-screen instructions.
Our Kodak Z612 won't switch back to the memory card
Dont you worry On that.,
Here's the thing you need to Do.
-Turn On the Camera
-Press menu
-Press down arrow 10 times
-Now you should see the word IMAGE STORAGE then press Ok Button
-Now under Image storage it will provide 2 options if your press Ok., Highlight or choose the word Auto then Press Ok.
Now since your image storage is On auto it means that It will automatically Go into your Memory card everytime you insert you memory card in your Camera., GudlucK!
4helpful
Switching from internal memory to memory card
Push the MENU button and advance through the options until IMAGE STORAGE comes up. Setting this for AUTO will route all new pics to the memory card, using internal memory only if the card is full.
1helpful
Internal memory full-
There should be a way to do that in the setup menu.
Kodax 8.2 mega pixels
I found this part of the manual helpful:
www.kodak.com/global/plugins/acrobat/en/service/manuals/urg00239/CX7330_GLB_en.pdf
You have to set the storage to internal memory, then you can copy to a memory card.
Hope that helps!
No Flash function on Kodak Easyshare Z612
To both, I'm afraid you need to send the out camera for repair.
Camera flashes use a capacitor that holds the electric energy for the flash. It takes some time to charge and discharges very rapidly to generate the light pulse. Capacitors are notorious in their reliability. They tend to disconnect and die or short circuit and die.
In camera1234's case it might just died disconnected.
In sheranne case it might died short circuiting. In this case the camera should not be used since the battery might explode.
Kodak easy share z612 will not turn on to take a picture
When the battery dies, usually the camera will retract the lens if possible. If the battery is so dead the lens can not retract, I would recommend trying to charge or change the battery. Or try to turn the camera on, and then manually shutting it off if you can.
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
