Question about Uniden PC68XL (40 Channels) 2-Way Radio
Uniden pc68xl how to install modulation swing kit on uniden pc68xl or how to improve more amps on the radio
This is no solution but rather a suggestion,I bought a PC68XL from a for 68.00 total with a mosfet swing kit installed,I was able to contact the seller before I got the radio ...what i asked him was what was the radio going to dead key in turn he told me some rididculous amount like 5 watts swinging to 25 ... I told him I wanted the radio to dead key one watt and swing to whatever it went to(it ended up at 3/4 swinging to 7),I have a small amp 2 mrf455's this setup does key the amp and has my 90 watts swinging from about 18 to the 90... I do use a power mic actually 2 different ones both sound great (a 575-M6 and the newer model of the Minuteman) when you keep the mic gain on the radio at about halfway up and the mics just cracked open enough to see your meter at 100% otherwise they will squeal ... I use a Wilson 5000 with a flat swr... I do get my head beat in talking skip but I do talk(on a daily basis) on Channel 11 mostly and do get an honorable mention on channel 6 from time to time ... talked to Manchester, England just the other day on 11 so this set up works for a grand total of about 250.00 bucks. Moral of the story is you do not need to pump up the wattage on these radio's.
Posted on Mar 03, 2012
    Novelist:
    Champion:
  • 211 Answers
Since this is illegal to do I can't instruct on this matter, but you might do a search on cb sam website. good luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 06, 2008
How do you turn down the modulation on a uniden pro510xl?
Not getting enough voltage or amps will make them squeal,also. Run both the amp & radio directly to the battery using some heavy wire. I use #8,but I would like to have some #6. Also,those stock little mikes on the 510 are a lot to be desired. Get someone to let you try a GENUINE Turner Roadking 56 & see if it still squeals. Lots of good tweaks on CB Tricks site. Good luck.
May 14, 2014 | Uniden Bearcat Pro PC68XL CB Radio
I can,t get any modulation on my uniden pc68xl cb
you shouldn't be able to hear your modulation anyway,unless you have talkback. If you can't hear to well get a mono set of head phones or turn your radio volume up.
Mar 20, 2013 | Uniden Radio Communications
How do i peak a pc68xl
clip D-9 diode for max mod. tune slugs L-8 and L-10 for max swing
near back of radioL-8 has factory wax remove very careful tune slug out for max wattage output L8 L10 by rear of radio in heat sink look like tuning slugs 1 has factory wax on it remove to tune be very careful tuning slug is easy to break
Feb 01, 2013 | Uniden Bearcat Pro PC68XL CB Radio
NO SOUND ON PC68XL UNIDEN CB RADIO
It might be the mic wiring. They like to brake off the back of the plug. If you need repair work. www.herzjoe3@gmail.com
Jun 26, 2012 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Best modulation for PC68XL
Most Cobra / Unidens are easy by clipping D9. On this one D9 and L19. Just turn up L19 to top. Clip D9 diode. spread coils 1/16" inch. Also use 100uf capacitor (-) toward final across JUMPER staple near Final Transistor in back. Use meter(adjust to best swing) spread back coils,remove L10,L20 slugs or adjust them to top. The only radio that clips different than D9 is Cobra 29Ltd (D11) or Uniden pro510xl(D14).
Oct 08, 2010 | Uniden PC68XL (40 Channels) 2-Way Radio
No modulation
I think you will find the Finals are blown in this radio.
usually caused by a bad antenna or a problem with the coaxial cable.
May 26, 2010 | Uniden Bearcat Pro PC68XL 40-Channels Base...
CB Radio
Hi and welcome to FixYa,
Have you tried VR5? Not much on the mods other than adjusting L8-10 for AM power.
Good luck and thank you for asking FixYa.
Aug 11, 2009 | Uniden Radio Communications
Need help in trying to boost mod/wattage on pc68xl dont have cash to take to radio shop and also add talk back. someone needed my conex more than i did use my radio everyday thank-you for your knowledge in...
Not much DIY (do-it-yourself) modifications on a Uniden Bearcat Pro PC68XL  Some that could be tried:
  • VR5 - adjust for max / best modulation;
  • L8, L9 & L10 - change coil spacing for maximum carrier output.
Aug 01, 2009 | Uniden Radio Communications
ONLY 2 WATTS DEAD KEY AFTER BEING PEEKED/TUNED AND MOD KIT.
it sound that a can has been set of balance, or the output  transister has crashed. did you up grade the output before ajusting for more output.
May 20, 2009 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Uniden PC68XL (40 Channels) 2-Way Radio Logo
478 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
Greg Cann
Greg Cann
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
