JUST PURCHASED IT AND I AM NEW TO THIS LAPTOP IT HAS USB CABLE BOYH TV AND LAPTOP
SOURCE: flat scren wont turn on
Try a power drain:
1. Unplug the TV's power cable so that the TV is not grounded to the house. Do not simply
turn off a powerbar if one is in use.
2. Press and HOLD the TV's own power button for one minute to drain the internal capacitors.
3. Plug the TV back into a wall outlet versus a powerbar, if one is in use and see if this
makes a difference.
If the TV does not turn on, are you able to see any indication from an internal LED light in the back of the TV? If not, the problem is usually with the power supply. If you do see a LED light anywhere, then you know the TV is getting power but the TV's mainboard is at fault. In either case service would be required if the power drain does not resolve this.
SOURCE: Don't know where to hook cable wire into my W4207-Flat Screen
Nice tv - but its a monitor, so there will NOT be a RG6 cable connection on the set. you have to provide a tuner to get signals OR use a cable box, sat box, etc.
SOURCE: New mintek flat screen tv won't do anything
Its not the power pack. The problem is with the dvd player which is also where the cable inputs converts through to the tv. if you are lucky enough to find a new internal dvd unit then you are in luck but I have'nt been able to. Your problem is an old isuues at least 2 years old...Sorry no Mintek tech support available.
SOURCE: I purchased a new sony 40 inch flat screen t.v. I
Plug it into the RF input. It should be marked as ANT (antenna), Cable, or ANT/CABLE. Do a Auto Program in the Menu and you should get channels there is a cable or antenna source.
SOURCE: new flat screen hdtv has a fuzzy picture
Yes you will get a better picture quality out of a cable box if you get an HD cable box.
The reason you are getting the diminished picture is due to the signal you are feeding the TV is an analog signal. The newer HD TV's are made for digital TV and this older technology shows all its flaws on this type of TV.
When you get the new box understand that the same channels you are getting plugged directly into the tv are still going to have some grainy look to them but the good thing is that a lot of them are starting to be rebroadcast on HD channels and that is where your new toy will truly shine.
Enjoy your new TV...
Good Luck...
