Question about Whirlpool Estate TAWS750PQ 27-Inch Washer
Whirlpool Dryer not heating
Hi there.  We have a Whirlpool LER4634J model dryer that now refuses to heat at all.  We've noticed over the past few weeks that sometimes it'll take two cycles to dry thoroughly, but today there's no heat at all coming from it.  We had a power outage last night for a few minutes.  Does that have anything to do with it?
quit heating suddenly. Checked heating element with ohm meter, no short.
  • 248 Answers
If it was taking longer to heat it probably has a restricted vent. Check for lint build-up. May also have blower cage full of lint.
UNPLUG UNIT FIRST!!
To access blower cage, remove rear panel. Remove four screws holding duct on left side in place at bottom. Remove two screws at filter area on top. Pull duct out at bottom and reach inside and remove lint.
Also ohm out all thermos. Check thermos on side of heater. Check white one to right of duct you cleaned. Check between larger two wires on four wire thermo. All should show zero resistance.
Check between two outside blades of plug. Should have about 220 volts. Pull plug out slightly and carefully check for power between outside blades. Then check for 110 volts from center to either outside blade. It only requires one 11o volt circuit to run, but both to heat.
Posted on Nov 09, 2007
Whirlpool dryer: Running but hot air stops coming.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 13, 2010 | Whirlpool LER4634J Electric Dryer
I have a whirpool dryer Model LER 4634 PQ0. The dryer turns but does not heat. What could the problem be?
heatman101
Sep 07, 2010 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer runs but does not heat
heatman101
Sep 01, 2010 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer model LEW0050PQ doesn't heat up
heatman101
Aug 28, 2010 | Whirlpool LER4634J Electric Dryer
LER4634J Electric Dryer: dryer will not heat...
heatman101
[p]
May 17, 2010 | Whirlpool LER4634J Electric Dryer
Have a Whirlpool dryer 6 yrs, last few weeks noticed that the drying cycle took longer, today the dryer goes on, turns, but does not heats up. Can you help me? I'm desperate.
If you have a gas dryer...
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 15, 2010 | Whirlpool LER4634J Electric Dryer
first check the circuit breaker in the house, turn it off then back on. if that does not do it then let me know so we can go to the next step. Mike
Jul 14, 2008 | Whirlpool LER4634J Electric Dryer
This can be due to malfunctioning of any of these 4 devices..
1)Heating element
2)Thermal fuse
3)Thermostat
4)Timer motor
For more info and troubleshooting checkout this link..
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Oct 22, 2007 | Whirlpool LER4634J Electric Dryer
Washing Machines Logo
229 people viewed this question
Dan Webster
Dan Webster
Sal De
