Question about Dryers
The fan motor is humming. how do we eliminate the
The fan motor is humming. how do we eliminate the noise?
  • 67 Answers
If it's turning then switchit off.
Clean the fan blades and dry them
lubricate the fan motor bearings
Otherwise you will have to buy a new one - sorry
Posted on Jul 02, 2009
Model 28870-420 ceiling fan. Why don't lights respond to remote or pull switch and motor just hums?
Your fan may have to be "reset" to restore light response. Turn off power at the source, not at the fan. Wait for a few minutes while you remove remote batteries and press all buttons to eliminate a "stuck key" problem. Reinstall batteries, then turn on power again. Try using the remote to turn on lights. If no luck, the remote may need new batteries or the receiver could be defective.
The motor hum could be caused by a broken capacitor connection or defective capacitor at the motor.
Dec 22, 2015 | Hunter Dryers
JVC - Turntable - QL-F4 - Noise coming from the motor ?
You don't say whether your turtable is grounded by a separate wire but in some cases grounding is necessary to eliminate hum.
Feb 25, 2014 | JVC Audio Players & Recorders
Humming noise. Seems to be coming from the fan.
Your freezer humming noise is likely coming from either the fan motor or the ice maker.
Jun 28, 2010 | KitchenAid KSCS25FKSS Side by Side...
There is a humming noise coming from fan no matter what speed it is on. I have run the fan for hours and still humming
The key to a quiet fan is to isolate the motor vibration from all other parts. This occurs, in the majority of fans, in three places: between the motor and the blade brackets, between the blade brackets and the blades, and between the downrod/motor flange and the mounting bracket. Some fans also have vibration-isolating material between the mounting bracket and the ceiling. If your fan makes a noticable humming noise, inspect it for the above mentioned types of vibration-isolating material. With the exception of the rubber flywheel, if your fan is lacking any of the above, they are easy to add and should solve the majority of humming problems. You can always add additional material as rubber washers and spacers are readily available.
Jun 09, 2010 | Hampton Bay 52 In.Carriage House II in...
38CKC036 Air Conditioner: outside fan will not come on makes a humming noise...
If the humming is your compressor running (feel the large copper line going into the unit, it should feel cold aftter a few minutes of run time) then the fan motor or the capacitor or both need to be replaced, check for voltage to the fan motor when the unit is "humming" if it has voltage and will not start replace the fan motor and the capacitor. hope this helps.
May 18, 2010 | Carrier 38CKC036 Air Conditioner
Humming noise
If you are using a dimmer switch to operate the fan instead of a fan speed controller, that is the cause of the humming. If you turn down the speed to the lowest setting and the hum gets louder, then your controller needs to be replaced.
Sep 13, 2009 | Hampton Bay 24750 Huntington III Ceiling...
New ceiling fan . Motor has humming noise.
Return it while it is still under warranty.
May 16, 2009 | Dryers
We have a carrier heat pump that is making alot of noise one guy says its the compressor other says it the fan motor and run componit what do I do its under warranty It 3 years and is surpose to be the...
" Try the process of elimination, ask them to disconnect one or the other at a time! Cause theres uppose to be only 2-sounds outside any way ,the fan swishing sound and the compressor sound, a machine humming sound.!
Aug 22, 2008 | Carrier Heating & Cooling
Tv makes humming noise when on. how can I eliminate or reduce the nose?
Some of the larger TV's are DISH ready, meaning that they have the tuner inside for SAT TV. The SAT tuners often have an internal fan that makes a humming noise. If it sounds like something other than that, you might have a bad component in your sound circuit that allows 60 HZ hum through the speakers.
If it is a rear projection LCG TV it has a fan in it to cool the bulb. You will hear the fan if you listen closely. It usually cannot be heard over the volume.
The fluorescent bulb and electronics inside make humming sound naturally. Kinda like when you turn on a lamp, and some lamps make a low humming sound.
Apr 03, 2008 | Televison & Video
Dryers Logo
363 people viewed this question
Top Dryers Experts
