Question about Weber Genesis Silver B Grill
Change weber ignitor battery
Change battery on ignitor
What should I do when the ignitor of my weber performer does not work?
Replace the battery (if it has one). If all you do is hold down the button and it starts to click then you have a battery ignitor.
Jun 22, 2014 | Weber Performer Grill
How do i change the battery in the weber E310
Debbie, to remove the old battery, unscrew the push button cap on the ignitor and you will see the battery inside the holder. Take note of which way the old battery is facing before removing it. As that's the direction you want to install the new battery. Once you remove the old battery, check the holder for any corrosion on the battery contacts. If you see any, cleaning it off using a Q-Tip and some WD40 will do the job.
Hope this helped you. Please let me know. Thanks.
Jun 27, 2011 | Weber Genesis E-310 Gas Grill
Ignitor issue. Changed battery, all wires seem to be connected. It was left outside this winter. How much to replace ignitor module?
The ignitor module sell for $16.95 at the following website http://www.allpartsgrills.com/item597838.ctlg
But before you order one, check the battery holder for corrosion and clean it with WD40 and a Q Tip.
Also, make sure you installed the new batter properly. The Positive (+) end should be facing you, when you insert it into the holder. Check all the spark ignitors at each burner to make sure they are clean and grease free. Alcohol and a cotton ball works well to clean them.
Hope this helps you.
Apr 28, 2011 | Weber Genesis E-310 Gas Grill
The ignitor does not work
Since your model Weber grill has crossover electronic ignition. I have to ask, have you changed the battery in the ignitor button/module? If so, is the battery facing the right direction? If the answer is YES to both of these questions, then the electrodes at the burners may be covered with grease and won't spark or the wiring to the electrodes may be loose and it has lost the ground. A cotton ball dipped in alcohol works well to clean the grease from the electrodes. Tracing the wiring will give you an indication on whether the connections are loose.
Hope this helps you solve the problem.
Mar 21, 2011 | Weber SPIRIT E-210 (NG)
My weber spirit 310 igniter will not work. It does not click or make a spark. I have changed the battery. I did notice that the battery chamber was very corroded so I cleaned it out but still no click....
I suspect that the corrosion you found has taken it's toll. You will need to replace the the ignitor box.
if it's still under warranty, Weber may cover it. Either way, you can get the part from Weber on line. Make sure you have your Model #, Serial # of the Grill and the date and proof of purchase.
Feb 13, 2011 | Weber Spirit? E-310
How do i change the battery in my weber genesis grill igniter?
just a stab in the dark but my grill has the battery in the ignitor button itself just unscrew the lid and replace it i hope this helps
Jun 28, 2010 | Weber Genesis E-320 Propane Grill
Summit ignitor Worked fine yesterday, today no ignitor.
Check your ignitor wires for broken or disconnected connections.
May 14, 2010 | Weber Genesis Gold B Grill
Ignitor doesn't work
change the ignitor it is bad weber might send you one if you call them
Apr 18, 2010 | Weber Spirit? E-310
Ignitor on performer grill stop working. Can
Call Weber at 800-466-1071 and order the ignitor kit: http://www.weber.com/publicSchematic/view.aspx?model=841004&Sequence=26&Suffix=
Aug 22, 2009 | Weber Performer Grill
Weber q 200 all of a sudden won't ignite- just clicks away
Most ignitors work of a battery which makes it spark. find the battery and replace it
Apr 20, 2009 | Weber Q Grill
Weber Genesis Silver B Grill Logo
162 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
