It says "please scan channel" after scanning channel it keeps repeating
If you tv has a "menu" try to find the function that "resets" your tv back to factory settings.
Main system control memory IC fault. Contact any service technician.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
SOURCE: Auto Scan doesn't pick up any channels.
In the main settings, there should be an option for AIR or CATV, air is for non-cable and CATV is for cable tv. This has to be on the correct setting before you autoscan
SOURCE: new tv. won't work
Press the input button and select where you have the satellite plugged in.
SOURCE: I am looking for the owners manual for a dynex 32
Here's a link to the manual...
http://www.dynexproducts.com/skins/skin_1/Topics/Documents/07-062_DX-R32TV_WEB.pdf
SOURCE: I bought a 32
Sounds like a bad tuner, replace the tuner that just may fix it. Either that or the power supply, is failing to supply the correct tuning voltage, and/or the tuner voltage..
SOURCE: I cannot program channels on my Dynex Model:
I JUST GOT A 26 NCH DYNEX FLATSCREEN AND AS I WAS WATCHING FOOTBALL IT JUMPED,SKIPPED CHANNEL'S OR WHAT NOT FROM 1014 TO 46.2 ON ITS OWN. WHAT IS WRONG?? OR WHY WOULD IT DO IT??
