Question about Husqvarna 531003384 Ignition Module Coil 531 00 33-84 Blower Part
How do i replace the ignition module in the 1994 pontiac bonneville
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
You have to remove the coil packs and its under them
Posted on Sep 03, 2014
SOURCE:
Need a picture of control module for 1998 pontiac bonneville se 3800
There are several control modules.
This is the engine control module.
This is the ignition control module.
Hope this helps.
Jan 02, 2014 | 1998 Pontiac Bonneville
1994 pontiac bonneville se blower control module
Under the bug screen on the passenger side engine compartment.
Aug 01, 2012 | 1994 Pontiac Bonneville
I have a 1994 bonneville i have fuel and fire ignition module is good i pulled the 1 and 4 to test the cps and i got fire any sugestions
Take the handle of a screwdriver and tap on the mass air flow sensor while someone else tries to start it.If it starts then take the mass air flow sensor off and clean the small thin wires with a non-chlronated brake cleaner and let dry for 10 minutes and re-install.
Jun 05, 2012 | 1994 Pontiac Bonneville
1994 bonniville 3800 engine problem cranking problem. installed feul pump,fuses. still want start. i am not a mechanic so please inform me
FIRST WE HAVE TO GO BASIC. THE MOST COMMON PROBLEMS ON THOSE MODELS WERE CRANK SENSORS AND IGNITION MODULES 99.9% OF THE TIME. U ARE NOT A MECHANIC SO ITS KIND OF DIFFICULT TO DIRECT U. THE IGNITION MODULE IS VERY EASY TO REPLACE BUT THE CRANK SENSOR IS A LITTLE MORE DIFFICULT. TELL ME THE DIRECTION U WOULD LIKE TO TAKE. I DONT WANT U TO GET DISCOURAGED
Jul 22, 2010 | 1994 Pontiac Bonneville
1998 Pontiac Bonneville SLE will turns over but will not run
I would check to see if the spark plugs are fouled. Or you might have a bad ignition control module (mounted under the coil packs). Auto Zone can test the ignition control module.
May 19, 2010 | 1998 Pontiac Bonneville
How i cant see a picture of ignition control module of pontiac bonneville '95
you can see yours if you trace the spark plug wires to the coils. The ignition module is under the coils
Jan 31, 2010 | 1995 Pontiac Bonneville
1994 pontiac bonneville fires up but stalls imediatly
WOW a 94 with 46K on it thats rare. Your computer may be bad it sends the pulse to the injector.
Apr 09, 2009 | 1998 Pontiac Bonneville
No spark from the coil packs
Check the wiring and make sure your getting 12V to the module (under the coil packs) when the ignition key is turned on. If you have 12V then ohmmeter the coils. The primary side is like .5-1.5 ohms and the secondaries are in the 7500 ohm neighborhood. If all this checks out OK the module would be the culprit.
Mar 21, 2009 | 1994 Pontiac Bonneville
Gas milage dropped from 26mpg to 21mpg after replacing Ignition Module in 1993 Pontiac Bonneville. WHY?
did you buy it at the dealer or autoparts store factory module is made for yourcar aftermarket are made for a lot of cars they are the not the same
Feb 06, 2009 | 1993 Pontiac Bonneville
Husqvarna 531003384 Ignition Module Coil 531 00 33-84 Blower Part Logo
51 people viewed this question
Top Husqvarna Garden Experts
J. Bradshaw
Jay Finke
Jay Finke
lnbn1975
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
