I have a numark cd1 combo and i need to connect it my preamp and
I have a numark cd1 combo and i need to connect it to my preamp and equalizer and my power amplifier
  • 43 Answers
1-RCA outs on the cd1, right? Route to ins on the preamp (use adapters if necessary, you don't say what pre and eq you have)
2- if the pre has an effect loop/aux bus or whatever, install the eq in the loop, and output the pre to the ins on the power amp; otherwise route the outs from the pre through the ins on eq then to power amp ins.
Posted on Aug 12, 2009
How to hook up a 7 band pioneer equalizer great 470 to a Kenwood kr-v6030 receiver
Connecting an Equalizer to a Receiver Before beginning, purchase RCA cables. In order to run the signal from a stereo receiver to the graphic equalizer and then on to the amplifier, two sets of RCA cables are needed. These are basic cables used to connect auxiliary components like record players and CD players. The length of the RCA cables should be about the same length as the distance between the receiver and equalizer.
1. Connect Graphic the Equalizer to the Receiver
The first step in this setup is to connect the graphic equalizer (EQ) to the receiver. Most receivers will have preamp-in and preamp-out connections. Some have tape monitor connections. It's preferable to connect the EQ to the preamp-in or preamp-out because the tape monitor won't allow for connection to the amplifier as well.
2. Connect the RCA Cables
The first set of RCA cables should connect the receiver and equalizer. Connect one pair to the preamp output channels and the other end to the left and right input channels on the EQ. These are on the back side of the equalizer. Usually, the colors will correspond to the RCA plugs. That means connect the red plug to the red jack and the white plug to the white jack. Then connect the second pair of RCA cables between the receiver and the amp. Match the colors in the same way.
3. Connect the Amp to the Receiver
Now the amp can be connected to the receiver via RCA cables in the amp inputs on the receiver. This will create a loop from the receiver through the EQ and amp and back to the receiver so that all three units are connected.
4. Test Graphic Equalizer
Turn on the receiver, amp and equalizer. Once they are powered up, try controlling the sound with the equalizer knobs. They should fine tune the music according to your preferences. It's easy to change the frequency response or tone of the music with the equalizer knobs.
May 09, 2016 | Pioneer Audio Players & Recorders
Graphic equalizer how to connect for my turntable to work with it
There should be the connections from the turntable connected to the input of the equalizer then the output of the equalizer to an amp
Some turntables require a preamp so refer to your turntable manual.
(Some equalizers act as a preamp) You wont hurt it by trying it.
Jan 04, 2013 | Mitsubishi Da-g108 Stereo Graphic...
Blown fuse Numark cd1
what fuse blown and did u replace and then it stopped??????
Jun 16, 2012 | Audio Players & Recorders
How to plug up a Numark tt-1700
Like any other turntable - into a Phono preamp.
Web search "Numark TT 1700 manual". It's at numark.com.
Aug 12, 2011 | Numark TT1700 Turntable
When setting up a sound card to my m4 numark 3 channel mixer do i have the switch to phono or line
"PHONO" is ONLY for an old school turntable that would require a PHONO preamp, so that leaves, uh, LINE.
It's more than a matter of gain as Phono cartridges require special equalization to restore flatness to the sound recorded in a vinyl groove.
Mar 17, 2011 | Nu Mark Numark Dm3050 3-Channel DJ Mixer...
Does the numark tt200 have an auxiliary output? Do i need a phono preamp?
do'se it have auxiliary hookups in the back if not then buy a preamp
Jan 03, 2011 | Numark ttUSB Turntable
My numark x6 mixer does not work, it powers on, no output
Unless you can find someone local to fix it , you'll need to get something else
it's something internal broken and probably not an easy home fix
Nov 02, 2009 | Audio Players & Recorders
Where do I connect the ground wire from my amp to Numark TT USB?
i used to have stanton t80s,had the same problem no gnd on deck but diddnt need it there waqs no bad earth so if it sounds good leave it
Jul 18, 2009 | Numark ttUSB Turntable
Numark
You need a new adaptor...the wires have lost their connection in the cable or plug which isnt user servicable
KK
Aug 29, 2008 | Nu Mark Numark Cd-Mix-2 Dual CD...
112 people viewed this question
 Grubhead
Grubhead
