Question about Panasonic NN-T990SA Microwave Oven
The carbon monoxide detector beeps when I run the microwave.
The detector is 30 feet away, around a corner, 18 inches from the floor. Only seems to do it when running the microwave at full power. The microwave is a 1200 watt Panasonic with the inverter system. The problem just started about a week ago. We've had the microwave for 7-8 years, the CO detector is about 2-3 years old.
  • 578 Answers
Uplug the micro wave for the same amout of time the dector go off and see what happen if it goes off check the battery and replace them and do the same as above test to see if dector is not working properly
Posted on Jul 01, 2009
Measurements to replace R 1460 over the range microwave
Almost all over the range micros are 30 inches wide. They did make a few 36 inch models but most are 30. Top to bottom back measurement can be between 16 to 18 inches. Most makes are similar in size. Back wall mounting plate will have to be exchanged since each company has a slightly different design but the wall plate comes with the new unit along with mounting hardware.
Apr 14, 2015 | Sharp Microwave Ovens
WHAT IS THE CUBIC FEET OF JVM1339WB-002 GE MICROWAVE SPACE SAVER?
Determining the cubic feet of any given appliance, Microwave, Oven, Freezer or Refrigerator is quite simple.
Follow these steps.
Open the door of your microwave and measure the length, width and height in inches of the interior cavity.
Multiply the length by the width by the height using a calculator to get the total in cubic inches.
Divide the cubic inches by 1,728, which is the volume of a cubic foot. The resulting number will be your microwave's measurement in cubic feet. You can also use an online conversion calculator to simplify matters
Hope that helps
Sep 12, 2014 | General Electric Microwave Ovens
Micowave continues running after time is up
This can be two things that I know of 1 is a timer defect and the other is someone has placed some type of metal ie utensil, foil, can whatever into the microwave - either way you should replace the microwave and its a fire hazard to your home and others around you and the cost of a new unit is not worth the losses a fire can bring.
Jan 14, 2013 | Maytag Appliances Over-the-Range Microwave...
We have the GE JVM130H 001 microwave. I am trying to figure out what is the cubic feet capacity of this microwave. Can anyone tell me?
Hi, W/D here.
Here's an easy way to calculate your cubic feet: measure and multiply (in inches) the width X depth X height, then divide by 1728. This will give you cubic feet.
For example, if a microwave measured 18" wide X 18" deep X 12" high, it would be 3888 cubic inches; divided by 1728 (cubic inches in one cubic foot) = 2.25 cu.ft.
Best regards, --W/D--
Please take a moment to rate this solution. Thanks. --W/D--
Mar 19, 2011 | Microwave Ovens
Replace vent over stove with microwave & the
So are you saying that the vent hole doesn't line up with the microwave vent hole? I had a similar problem, it didn't matter since most of the new over the stove microwaves can vent back into the house as an option.
Sep 14, 2009 | Microwave Ovens
When on spin cycle, Maytag MAV5057AWW vibrates excessively more so than just an unbalanced load. When I open the lid the whole tub and agitator is moving around alot forward and back as well as side to...
make sure you loads are balanced, put heaviest clothes in first... if you can rock it by hand then the legs are not adjusted properly. If you stand 2 feet away from front of machine, jump up and down and see it move the floor is soft and you need 2 sheets of plywood to make 1 1/2 inches put under the machine
Aug 16, 2009 | Maytag MMV4205 Microwave Oven
Microwave turned on when empty
The magnetron will be damaged and now emit low output as there is nothing to absorb the energy.
I would dispose of it and get a new one.
Sep 01, 2017 | Panasonic NN-T783SF 1350 Watts Microwave...
Size of older GW Microwave
If you want to calculate the volume of an object and have the answer in cubic feet.
Volume=Length X Width X Height
With the dimensions you give
Volume=12.5in X 37in X 20in
Volume=9250 cubic inches
To convert 9250 cubic inches into cubic feet you need to understand that there are 1728 cubic inches in 1 cubic foot.
L X W X H = 12"X12"X12"=1728 cu in
You then multiply 9250cu in and (1/1728cu ft) Really you are dividing 9250 by 1728.
your answer is 5.35 cubic feet.
12 inches in 1 foot
144 square inches in 1 square foot
to convert you put the unit you want to keep on top of the dividend.
to conver to to feet ( randomly selecting 100 inches)
Example converting 100 inches to feet
100inches X ____1ft____ = (100/12) = 8.3 feet
12inches
or cubic inches to cubic feet
4000 cubic inches to cubic feet
4000cu in X ____1cu ft____ = ( 2.33 cu ft)
1728 cu in
if you notice that the units on top and bottom of the dividend cancel each other out leaving the numerator (top number) as your unit.
it also works in reverse
2.33 cu ft X ___1728 cu in____ = (4000 cu in)
1cu ft
Jun 03, 2008 | GE JE1540 Microwave Oven
Panasonic NN-T990SA Microwave Oven Logo
105 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
