Question about Toshiba TheaterWide 62HM84 62" Rear Projection HDTV-Ready Television
Blue shadow Hello, I have 42" Toshiba rear projection and it developed a blue shadow around everything. and it will not converge. I heard the green bulb might be out but am not sure how to replace this or the process on checking if this is the problem. Thank you
  • 767 Answers
The blue tube if fine
you need to replace two convergance
chips or have a shop do it.99.9% shure
the chips are cheap around 20.00-30.00
etch and even less for the generics 10.00-16.00 ,so dont let the shop charge you
to much for the dirt cheap parts.
Knolage is Power
Posted on Jul 02, 2009
My tv image is showing shadows in red, blue and green. I tried to align my image and it said there was an error. Do I need new bulbs or is it a more serious problem.
bourgen,
Your convergence circuit is bad. I have a tip at
http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics
which explains the problem, how to repair it and where to get the parts at the best price.
Thanks for using FixYa and for the great rating.
hardrocko
Feb 28, 2011 | Toshiba 42H81 42" Rear Projection...
Toshiba model 42H81 projection tv receiving blue and yellow shadows on screen.
Convergence is dead.Know how to solders?Must replaced the 2 convergence ICS and all it resistors.Tv Repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300 for parts and labors.
Feb 06, 2010 | Toshiba 42H81 42" Rear Projection...
I have a yellow line on the right side of my Toshiba 50 rear projection TV and yellow shadows around people
It sounds like a convergence problem---go into the customer menu and select convergence---set should offer center and multipoint adjustment--in the multipoint look to see if the outer crosses adjust--if red or blue will not adjust somewhere--bad convergence IC's.
Jul 17, 2009 | Toshiba 42H83 42" Rear Projection...
Ghost shadows on numbers and people
convergance problem comen problem with projection ics going bad and maybe some resistors need to take to shop or if you can solder good could do it yourself.
Feb 28, 2009 | Toshiba 42H83 42" Rear Projection...
Cross hairs
Hello, You need 2 convergence ICs if you cannot converge the red and blue lines on top of the green "cross hair". You should be able to use the front panel controls to move the red and blue around. If you can move them around and they just won't move completely on top of the green then the ICs are bad. The ICs are mounted to large,finned heatsinks and have numbers that start with "STK-" and have numbers following. These parts are available from http:\\www.tritronicsinc.com.
Dec 01, 2008 | Toshiba 42H83 42" Rear Projection...
Blue shadow
Good Day,jmurf1037;
Yes, you have a convergence problem.From what you say it sounds like the Convergence IC's have failed. Part number 267P150010, STK392-570, replace both IC's. They are on the middle board secured to a large heat sink.
Good Luck, big IRISH.
Aug 20, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Toshiba 42H81 42 in. Rear...
If you are referring to the convergence alignment of red,green and blue........will require technical and mechanical skills.....
1) Pull chassis
2) Replace both STK392-110 convergence IC's
3) Reset alignment as needed........................................T.
Nov 23, 2007 | Toshiba 42H81 42" Rear Projection...
Toshiba 42H82 convergence problem
Replace STK convergence IC's w/OEM or better parts.Senior tech soldering ability needed. Ex==Steel jumper wires feeding b+ to conv. IC's need resolder to prevent call-back.Also, best re-alignment done in service mode==consult service literature.
Sep 19, 2007 | Toshiba 42H83 42" Rear Projection...
Toshiba 56H80 Convergence Problem?
There are 2 large IC's in your set and one of them has burned out. These are called convergence output IC's and are usually the STK392-010's. A good idea would be to go ahead and replace both with the newer, upgraded STK392-150 IC's. A good tech can change those IC's in about an hour and a half, and when I do a housecall for a set like that I charge $150, but shops in your area will vary so be sure to ask around.
Sep 07, 2007 | Toshiba 56H80 56" Rear Projection...
Toshiba 42h81 picture shifted
Are you still working on your set? I can help......T.
Jul 31, 2007 | Toshiba 42H81 42" Rear Projection...
Toshiba TheaterWide 62HM84 62" Rear Projection HDTV-Ready Television Logo
97 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
