Question about Canon PowerShot A520 Digital Camera
Lens does not always open, batteries run down quickly
When I turn on the camera, the lens usually opens about halfway. Before taking a picture, I have to manually open it all the way. Also, the batteries run down quickly.
  • 1,305 Answers
The 520's are notorious for lens opening issues... I've had a few and any dirt or moisture in the lens shutters, and they'll get screwy.
Clean dirt with a little compressed air...not high pressure...
Batteries... set the resolution a bit lower, avoid alot of flash and zoom and you'll get better battery life... it's part the 520...carry spare alkalines.. always..
K
Posted on Jul 01, 2009
Lens Error: 0x12110000 when previewing pictures in camera.
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jun 01, 2009 | Sanyo Vpc-s1070w Digital Camera
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 22, 2009 | Sanyo Vpc-s1070w Digital Camera
Lens Error
Dec 17, 2008 | Nikon COOLPIX L4 Digital Camera
Camera turns on BUT then get "lens error restart camera" msg
Aug 09, 2008 | Canon PowerShot S3 IS Digital Camera
Lense Cover Stuck
Try blowing lots of compressed air around the open lens shutter to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Also with the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. A grain of sand in the mechanism is usually the culprit, and you want to try to dislodge it.
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and be aware this will void your warranty):
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Oct 01, 2007 | Canon PowerShot SD750 / IXUS 75 Digital...
White screen, won't take pictures, battery door won't open!!
Sony customer support is the place to go but I suspect a new camera is likely to be a more economic option
Jul 28, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Camera lens cover is sticky
You can open it up, but only as a very last resort. The above procedures usually work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk):
Jul 27, 2007 | Casio Exilim EX-Z55 Digital Camera
Lens will not come out of camera
There is a workaround for this problem, when the lens cover is open press down on the area of the lens cover on the "s" of Olympus. This can operate the switch that opens the lens etc. The long term fix is to remove the lens cover by removing the 2 screws at the base of the lens cover, take the lens cover off and gently clean around the switch which is behind the "s" of Olympus when the cover is on. I found that the grease/oil Olympus had used on the switch attracted dust etc and by cleaning this off the camera began working. Be careful when taking the lens cover off, there is also a very small metal plate that separates from the lens cover - don't lose it.
Nov 12, 2006 | Olympus MJU 300 Digital Camera
Canon PowerShot A520 Digital Camera Logo
106 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
