Question about Kenmore 63942 Dryer
Dryer not blowing hot air
Burner not firing. igniter not working nor does it seem that any propane is flowing either drum rotates fine and air blows but not hot
  • 72 Answers
You either have bad element or bad thermo disk or thermo fuse
Posted on Jul 01, 2009
  • derald haney Jul 01, 2009
    allso 1 side of breaker can trip it will run but not heat 110 v runs motor 220v heats
Gas dryer wont dry clothes
Assumptions;
The drum is rotating as usual
The clothes get hot or warm so the gas burner is working
If these things are true then check the outside vent for air flow. If it is weak less than expected, I'll guess that you have a clogged vent.
First check the outside vent for buildup. If it is clear then the problem lies somewhere upstream.
It can be messy, with lint blowing all over the place if you pull off the hose from the machine while it is running but if the air is comming out there then the clog is on down the line.
Jan 03, 2014 | Kitchen Ranges
Clothes are to hot to touch, already cleaned dryer vent and dryer is blowing a force of air out of back and through venting system. Why??
Check to make sure that your cycling thermostat is operating properly. Also make sure that drum is rotating. What it sounds like is that the machine has either an air flow problem or thermostat problem. Try running the machine with the vent off, only if it is electric, not gas dryer. Also check your blower to make sure it is tight on the motor shaft. That would impede air flow and cause overheating.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gary_58e9c3508cafe590
Jul 31, 2013 | Siemens Dryers
My dryer run all day and night if I would let it.And it takes one day to dry my clothes what is wrong with it
If it gets hot or warm in the drum but the clothes do not dry---the most common cause is a blockage between the drum, lint tube in the unit to the vent that flows the air to the exhaust outside.
If the drum gets much hotter than the air exiting the vent----clean all the from the drum to OUTSIDE.
Note: if there is not proper airflow and a lint build up exists there is the potential for a fire---Hundreds of fires are reported each year cause by this kind of trouble.
If the drum does not get hot inside you may have a bad igniter that heats the air (fires the burner uo inside the unit.)
Dec 07, 2012 | Roper RGX4634KQ Gas Dryer
Kenmore mod# 110.73012102, sounds like igniter is working ,drum turns, air blows ,but no heat
pop off the bottom panel,there's two clips that are on top of the bottom panel,stick a screw driver or putty knife in and pop the clips and pull out the panel to remove,start the dryer,if the flame ignites and then after a few minutes it doesn't ignite any more you have bad gas coils located on top of the gas valve,part number 279834 and they're around 25 dollars,if the flame ignites but goes out to soon most likely you have a blockage somewhere from lint buildup,pull off the vent line from the back of dryer and see if it runs any better,also unplug the dryer,remove the lint filter,remove the bottom panel and then remove the metal duct that the filter slides into and clean it out,vac and blow out all lint with a shop vac on the motor and inside the cabinet,if your vent line is a long run,remove it from the back of dryer and blow it out with a leaf blower,first check outside to make sure there isn't a cage or anything blocking the air flow before you blow out the line,if there is remove it and don't put it back.let me know how you make out and good luck.
Feb 22, 2012 | Kenmore Dryers
Dryer not drying clothes
Hello, does the dryer drum turn? If the dryer drum is moving. Is the dryer blowing hot air, cold air, no air at all? Now, if it's doing everything mention above escept blowing hot air then you'll need a new heating element. If not blow air, then the drum belt is broken, belt off, or the drum motor has gone south. It was put for a quitt. Which mean in New Mexico, they fired me, I don't work, no job, finished, I'am out of here, don't bury me with my wires exposed. I hope I was some help to you. have a nice day and be safe, GB. stewbison
Aug 20, 2011 | Dryers
I have a Kenmore series 90 gas dryer that has been converted to propane, model 110.74912200. the burner will light and stay hot for about 3 minutes and then will cycle off and only blow cool air. I have...
I would suspect faulty gas valve solenoids. These electrical coils are right above the gas valves and when energized, these solenoids open the valves to permit gas flow. It's recommended that if any are suspected of being faulty that both (all) be replaced at the same time. They will most likely come as a set from the parts supplier. Really sorry for your trouble and I hope this helped. Best wishes.
Sep 24, 2009 | Kenmore 73952 Gas Dryer
Neptune Gas dryer burner will not continue to fire
There's a good chance you need to replace the igniter. Careful, they are brittle !!!
Sep 02, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer doesnt blow hot air.
I find that quite often the ignitor is out of alignment or the glass window is covered with lint.
a gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes.
There are two common styles of ignitors, glow ignitors and spark ignitors. The ignitor ignites the gas either by heating up and glowing, or by sparking. If the ignitor fails, the dryer will not heat.
The easiest way to check the ignitor is to observe it. Remove the small access panel in front, select a high temperature setting and start the dryer. Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow or spark. If you see it glow or spark, then the ignitor is working.
Aug 19, 2009 | Kenmore Dryers
Propane gas range and oven Q; When the oven calls for heat I hear
no! never normal for that... check for upstructions in burner tube ..blow out with air seems to work
Mar 15, 2009 | Thermador P304CS Gas Kitchen Range
Air flow and heating problem inside dryer.
???? this doesnt make much sense, can see how you would be measuring air flow within the cabinet??? air blowing out unit strong means your gettin good air flow fom within, that is a direct relation as to the amount of (hot) air being pulled across the clothing
Jan 14, 2009 | Whirlpool LER4634J Electric Dryer
Kenmore 63942 Dryer Logo
107 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
