Question about Jenn-Air JGD8130 Gas Cooktop
Jenn-Air JGD8130 We've discovered that our new Jenn-Air JGD8130 gas cooktop does not produce high enough heat to properly boil pasta or fry food. The natural gas burners are rated at 10,000 BTU and 8,000 BTU. Can larger diameter venturis be installed, or the existing venturis bored out to increase the BTU output. The 8,000 BTU burners have a venturi diameter of 0.052 inches and the 10,000 BTU burners have a venturi diameter of 0.055 inches. The problem is not becuause of our gas supply since our previous 40 year old Hardwick range that this cooktop replaced before our kitchen wias remodeled produced plenty of heat to rapidly cook food.
The problem is the pot(s) is too far from the heat. Jenn-air needs to make a burner cover that is closer to the burner for boiling water...
Posted on Sep 08, 2008
Jenn-Air Cooktop JED8430BDS
That is an obvious burned wire, or burned thermal cutoff etc
Nov 09, 2013 | Jenn-Air JGD8130 Gas Cooktop
Stuck knob
if this is a oven you are lighting would be oven thermostat would contact surplyer as faulty goods dont try repair as will void garantee
Jul 29, 2012 | Jenn-Air JGD8130 Gas Cooktop
The gas controllers on my jenn air cook top no longer turn
I just had the same happen, I called the technician. He just sprayed WD-40 on the shaft and with a pair of pliers went up down and turn (spray,spray) until it started working again, well that was 60$ I hope it helps someone
Sep 28, 2011 | Jenn-Air JGD8130 Gas Cooktop
Burners will not light; there is no sound of the ignitor either
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
Aug 12, 2011 | Jenn-Air JGD8130 Gas Cooktop
I am using propane for my cooktop but all my pots and pans have been turning burnt black soot on the bottoms. It's ruining all my other dishes now from the dishwasher spreading it all over, We tried...
You don't have the right Gas to Air ratio..... Not enough air to the burners or you are running to low of gas pressure for propane... Propane takes a smaller orfice or operate than Natural Gas.....
You should have 10" of WC for Propane operation..
You will need a manometer to check it.
The flame should be a blue color with no yellow in it. There should be air shutters right at the orfice to each burners. You will have to play with the adjustment to get the best blue flame with no yellow in the flame.... Hope this helps.....
May 17, 2011 | Jenn-Air JGD8130 Gas Cooktop
Is 8000 btu.burner enough heat for general use
Hi, 8000 btu is a medium size burner, simmer burners are around 4000 btu, The largest are around 12000.
Feb 03, 2010 | Jenn-Air JGD8130 Gas Cooktop
Jenn-Air 30 in. JGD8130 Gas Cooktop
Yes. Buy a burner module. Sears sells them also most appliance part stores. (I am assuming you have the model with 2 knobs on the grill side) The electric version of burner modules is around $100 Gas should be similar price.
Jun 08, 2008 | Jenn-Air JGD8130 Gas Cooktop
make sure you have the correct orifices, make sure you have good gas pressure and make sure pressure regulator is ok.
also if the unit has been in service for a while check the orifice for build up a wire or needle will work to knock out any build up
Apr 23, 2008 | Jenn-Air JGD8130 Gas Cooktop
grab hold of the installed burner cartridge at he top of unit and pry up slightly, should lift up without much effort, if not try lifting front side. they jsut lift up and slide back in no screws hold them in place
Feb 21, 2008 | Jenn-Air JGD8130 Gas Cooktop
Jenn-Air JGD8130 Gas Cooktop Logo
544 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
