posted by jsmousse on Nov 08, 2007
I cleaned my unit a week ago, removed the plate inside and replaced it with a spare I had. When I put everything back together, the unit run just fine, however, it appears there is a problem with the unit, because I do not get the clean air smell in my house. I am not sure if this is a lack of ionization or another problem and I have no idea if something on the unit needs to be replaced or repaired. Any suggestions would be greatly appreciated.
Comment by jsmousse, posted on Dec 28, 2007
Thank you, your suggestion corrected the problem.
1 Other User Has The Same Problem
Comment by turbenc, posted on Jul 14, 2008
I had the same problem and followed your directions but my Breeze AT still does not produce the ionized smell that it did before. Any suggestions ?
Best Solution
posted on Dec 20, 2007
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
When you clean this unit, the plate should be soaked in a 50% amonia to water solution for about 8 minutes. Take a toothbrush and scrub each side of plate and let copletely dry. Take a qtip and dip in rubbing alcohol and swab each of the metal electrodes that touch the plate....This should have that freash air smell back again.!!
Rating Locked! (?) jsmousse has rated this solution as FixYa!
Suggest a new solution for this problem
Post a New problem for Ecoquest Breeze AT Living Air
Email this problem
Email this problem
Can you Help with these Air Purifiers problems?
Ecoquest Breeze AT Living Air Purifier
Breeze AT has completely...
Looking into to back of the... Answer This...
FAN WILL NOT RUN
FAN WILL NOT RUN
i have a living air / model... Answer This...
Repair Service
Find Air Purifier Repairman Near You:
