Question about Vitamix 36000 Work Top Blender
My vitamix 5000 just started making a high pitch noise when blending...
  • 3 Answers
SOURCE: 8 yr old vitamix 5000
Get an estimate at a local small appliance repair shop,that's what I did,and saved myself a bundle.
Posted on Apr 10, 2011
lauren940
  • 206 Answers
SOURCE: I was blending a slightly thick batter and the
Well it might just be over heated, let it cool for approx 20 minutes then restart if it doesn't then u may try switching electrical outlets, if that doesn't work then it needs to be replaced. I hope that this helps, if not please let me know and i will try and help you out as much as i can.
Posted on May 28, 2011
mc1bean
  • 3053 Answers
SOURCE: need vitamix super 5000 manual in order to use the
Hello, lawrence
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about blenders andpossibly yours, from
repair to trouble shooting it. http://home.howstuffworks.com/how-to-repair-small-appliances5.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 28, 2011
mc1bean
  • 3053 Answers
SOURCE: My 5-year old Vitamix 5000 has started leaving
Hello, afreden
Thanks, Mike
mc1bean
  • 3053 Answers
SOURCE: I have a VitaMix 5000
Hello, peter
Thanks, Mike
When i turn it onto high speed it willl fuse istanlty. (Even with somthing easy to blend like a smoothie) .Any ideas what could be wrong?
I would suspect a motor fault, most likely an insulation problem in the armature or the fields. Contact Vitamix for your local authorised service agent. Unless it has been assembled incorrectly it should not be one of the internal wires as they are supposed to be secured and correctly routed during assembly.
Mar 31, 2015 | Vitamix 5000 Work Top Blender
Vitamix 5000 runs only on high
Bad variable switch?
check out their site, they are awesome, and may help better.
Contact Us Customer Service Vitamix
Jun 05, 2014 | Vitamix 5000 Work Top Blender
High pitched noise with use
The problem was the seal was worn, allowing liquid to seep past into the top blade shaft bearing washing out the grease and ruining the bearing. The "noise" you heard was the bearing running without any lubrication. Both bearings and the seal needed to be replaced but I have not found a source for purchasing these. Vita-Mix Company does not sell parts, they sell units (outrageously priced units)!
Sep 03, 2012 | Vitamix 5000 Work Top Blender
When I make a frappacino I get lots of foam instead a slushie drink
You're blending at a high speed and air is getting introduced. Try a slow blend speed. This should solve your issue.
Jul 24, 2011 | Vitamix 5000 Work Top Blender
I was blending a slightly thick batter and the Vitamix just stopped! Will the machine start after awhile? Do you think it has just overheated? How do I find out ? My old Vitamix had a reset button at the...
May 28, 2011 | Vitamix Super 5000 Work Top Blender
Loose Object in Vitamix Turbo Blend 4500
Vitamix has a 5-year warranty. Go to their website and they will send you an empty box with a UPS pick up tag and fix it.
Apr 16, 2017 | Vitamix TurboBlend 4500 Work Top Blender
Vita-Mix 5000 blender shuts off under heavy blending loads.
first check the blades on the container thay should turn easy by hand if not thats your problem , you will need blades . blades turn easy ? you will need to replace the motor . the temp /overload has changed and is tripping to easy . this is common with people that use there vitamix for tough chores a lot . a lesser blender would just burn up a motor in a puff of smoke .a vitamix dies this way . in the end its the same you will need a motor
Mar 22, 2009 | Vitamix Super 5000 Work Top Blender
Manual for Vitamix 5000
Manual-Cookbook -Getting Started $0.99 1 bid. Buying Info 4d 21h 52m ...
shopping.superpages.com/vitamix+5000~BEFID_96301 - 60k - Cached
Jan 22, 2009 | Vitamix 5000 Work Top Blender
Vitamix 36000 Work Top Blender Logo
132 people viewed this question
Top Vitamix Blenders Experts
Craig Butler
Craig Butler
Holly...
Holly...
Are you a Vitamix Blender Expert? Answer questions, earn points and help others
