Sounds like its just 1 of the fans inside the case needs replacing or possibly the fan inside the power supply. These dont cost much and are easy to replace.
If it freezes up, I recommend you reinstall your operating system.
1) Get your product key: http://www.nirsoft.net/utils/produkey.zip
Run the program and copy the product keys.
2) Get your installation disc and reinstall, then type the product key you copied down, then reinstall your previous programs
The outside edge of all bearings have a maker and bearing number i.e. "NGK2604". Get the number then go to an industrial bearings company. They can look up the bearing and see if it is in stock and if not, they can look up a matching bearing from a different manufacturer i.e. " SAS3107". The actual dimensions will likely be available at the same location. By the way, most people have no idea what you mean by "dogbone". Do you mean the crankshaft main bearings?
