Question about Texas Instruments TI-83 Plus Calculator
I need help with a change of base formula problem.
Use the change of base formula to find the logarithm to four decimal places:log6.7(17). I'm not sure if thats how you would write it? anyone??
    Sniper:
  • 81 Answers
It's simple here some logs:
log x base y = log x / log y
log (x*y) = log x + log y
log (x/y) = log x - log y
you just need to know that the default base of log in calculators is 10, so log x mean
log x base 10 = log x / log 10,
so write log x / log y for log x base y example:
log 8 base 2 = log 8 / log 2 that is how you write it on calculator, hope it was helpful
Posted on Jul 06, 2009
  • 13 Answers
The formula of the change of base is (log x)/(log b), where b is the base and x is the value you are trying to take the log of.
Posted on Jul 07, 2009
Logarithm
The Casio FX-300MS does not provide base 2 logarithms as a single key operation. However, you can use the natural logarithm (ln, base e = 2.7182818...) and the formula
log2 ( x ) = ln( x ) / ln( 2 )
To calculate the base 2 logarithm of 16, key in
[ln] 16 [/] [ln] 2 [=]
and get displayed the correct answer 4.
The same simple formula also works for any other base, and actually for any other logarithms provided by your calculator. The FX-300MS also provides a logarithm to base 10 (lg). You could also
type
[lg] 16 [/] [lg] 2 [=] to get the solution to the problem above, or
[lg] 25 [/] [lg] 5 [=] to get the base 5 logarithm of 25.
Mar 20, 2014 | Casio FX-300MS Calculator
Change base log
The TI 86 has two logarithmic functions: natural logarithm (ln) and common (decimal) logarithms (log). If you need the logarithm in any other base than e or 10 you need to use one of the two equivalent expressions
log_b(x) =ln(x)/ln(b) =log(x)/log(b)
Here b is the value of the base of the logarithm and x is the argument (the value whose logarithm you are seeking). Of course the argument x must be a positive number.
Note: On the TI 86 the log function can calculate the logarithm of a complex number, according to the manual.
Sep 22, 2013 | Texas Instruments TI-86 Calculator
Entering,and working formulas with,Logarithms of Trigonometric Functions on a Casio fx-300MS.Converting Right Ascension to Ecliptic Longitude,without Latitude.Example:Log Cosine of Obliquity,(23.437778...
I am not sure there is a question expressed here. If you have a formula you want to use to calculate some quantity in it, state the formula, provide the known values and we will show you how to enter it. As to what it serves for, I for one do not need to know.
Sep 29, 2011 | Casio FX-300MS Calculator
How do i find the exponential root using the TI-30Xa calculator?
Using logarithms. For example, if A ^ X = 2; then X = logA(2);
This calculator only works in base-10 logarithms or natural logarithms, you should use the base conversion formula.
logA(X) = logC(X) / logC(A).
May 02, 2011 | Texas Instruments TI-30XA Calculator
How do i use log functions on the HP 39g+. For instance i want to use log10 1000 which should equal 3 or 3^5=243 so log3 243 should equal 5. If i press log the calculator shows: log( If i...
To calculate the common log ( LOG base 10) of a positive number, just press the LOG key, the one above the blue Division key, then enter the number and close the right parenthesis. Press the ENTER key to get the result.
If you want to calculate the log in a base other than e (natural) or 10 (decimal) logarithms, you need to make use of one of the equivalent formulas below
log in base a of a number b
log_a(b)=log_10(b) / [ log_10(a)] or
log_a(b)= ln(b)/ln(a)
Apr 19, 2011 | HP 39g Calculator
How to calculate 0.3log(base 2)0.3 using fx-991ms calc
Your calculator knows only the decimal logarithms log or log_10 and the natural logarithms (ln or log in base e).
So you cannot compute directly the logarithms in any bases other than 10 and e.
A workaround consists in using the relation
log in base b of a number a (log_b (a))
log_b(a)= (log_10(a) ) / (log_10 (b))
or the relation
log_b(a)= ln(a)/ln(b)
log_2(0.3)=log(0.3)/log(2) where log is log in base 10
Similarly
log_2(0.3)=ln(0.3)/ln(2)
As to the multiplicative factor you had at the beginning of your expression, just multiply the value obtained by one on the formulas above (both formulas will give the same result) by 0.3
Jul 18, 2010 | Casio FX-115ES Scientific Calculator
How can i get logarithms on the calculator
For natural logarithms Press [2nd][X], enter a positive number, close the right parenthesis and press [ENTER]. If the number is decimal the result is displayed as a number. If the number is integer, put a decimal mark at its end to have the result displayed as decimal.
For decimal logarithms use the ALPHA keyboard to enter the log( command, complete the argument and press ENTER
If you want to calculate log in base a of number b type log(b,a).
Apr 13, 2010 | Texas Instruments TI-89 Calculator
How do you change the base on the log function so you can do for example log with the base of 2 instead of base 10
Your calculator cannot compute directly the logarithms in an arbitrary base, but you have the means to obtain that indirectly.
You can use either of the conversion formulas shown on the screen capture (on the right). On screen capture ln stands for natural logarithm.
If you want binary logarithms (logs in base 2) you use the relation
log_2 (x) =ln(x)/ln(2)
or
log_2(x)=log(x)/log(2)
Use whichever formula is shorter to key in (without pressing the 2nd key).
Hope it helps.
Nov 16, 2009 | Texas Instruments TI-86 Calculator
How to calculate logrithm of base of any number in fx-991ms
you need the change of base formula:
log base b of m is ln m / ln b
So- to find log base 2 of 8, simply find ln8/ln2
(from Wikipedia - the proof also follows if you want to go look it up)
While there are several useful identities, the most important for calculator use lets one find logarithms with bases other than those built into the calculator (usually loge and log10). To find a logarithm with base b, using any other base k:
Oct 06, 2009 | Casio FX-300MS Calculator
I'm trying to calculate base number equation
You are victim of a confusion between terms. Base-n calculations are calculations using various numeration systems (bases) : binary (2), octal(8) hexadecimal (16) and decimal (10). What you want is how to calculate powers, logarithms, exponentials and these have also the notion of base; Log in base 10 is the common log, whereas natural logarithms, are logarithms in base e.
Back to your exemple: 5 times 5 and raise the whole to power 3?
In that case [(] 5 [x] 5 [)] [^] 3 or [X to the 3] if you have such key or
25 [^] 3, because 5x5 = 25
5 times (5 raised to power 3)
5[x] [( ] 5 [^] 3 [)] or 5 [^] 4 because of the rules about products of powers with the same base.
Hope it helps.
Feb 17, 2009 | Casio FX-115MS Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
3,874 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
