Question about Magellan Maestro Elite 4370 GPS Receiver
Gps wont turn on without it being connected to chargers
  • 728 Answers
This means that the internal battery of the gps system is completely dead and can not hold a charge. All you will need to do is replace the battery and it should work like new. The battery is fairly cheap to buy and replace.
Posted on Jul 01, 2009
    President:
  • 1,111 Answers
Thats a fairly new unit and i doubt if the battery is shot already.
1st verify that its charging. hook up the home or car charger, then go into the syatem settings and see if the battery indicator is moving left to right..if it is, its charging. if its not moving and shows a low battery, then its not charging.
Bill
Posted on Nov 18, 2009
Switches on ok but wont work when the charger is connected,the screen just shows the charging screen
The plug at the back of the GPS where the charger connects is shorted, very common issue on the Nuvi series.
May 26, 2011 | Garmin nuvi 200W GPS Receiver
Tomtom GPS does not turn on
HELLO!!
Charger gets very hot means the problem lies with charger which is not supplying the power to the system ... Try changing the charger ... and the charger wont cost u more than 15$
CLICK HERE TO BUY
GUD LUCK!!!
Dec 27, 2007 | Tomtom ONE GPS Receiver
Brand new out of the box, wont turn on
First when you get your insignia ns-cnv20 car gps receiver, you need to connect the charger into it and charge it for about 3 hours or till the battery is full, that is when you can power it on. Ensure that the battery is properly inserted, then the charger is okay by trying it out on another gps device. If you charge it for a while and it does not come on still, then you need to take it back to the dealer that supplied it to you. Since you just bought it.
Dec 25, 2010 | Insignia NS-CNV20 Car GPS Receiver
My Tomtom Gps wont turn back on, It's connected to a power source and that isn't helping either. What should i do?
The problem with your tom tom is either the battery or the charger. Either ways you need to test them both then replace the faulty part. That is why the gps receiver is not powering up.
Do not panic when your gps seems to be acting funny, There is no problem without a solution, and if it is beyond repair the solution will simply be that you replace the gps receiver.
Solution:
  1. Test the battery in another gps receiver, to see if it will power it on,
  2. Charge the battery in another gps receiver for about 2 hours with another charger then try to power it on,
  3. If it turns on, then it means the battery is okay and working fine, but if it does not turn on the other gps, then it means the battery is bad and need to be replaced.
Solution:
  1. Test the charger on another gps receiver to see if it will work.
  2. If it does not work then you need to replace it,
  3. But if it works then you do not need to replace it.
After carrying out the test, you will be able to detect the problem and solve it.
Hope this information helped.
Dec 23, 2010 | Tomtom ONE GPS Receiver
Garmin255w wont turn on
It could be that your batter has no charge. If you have plugged it into your car charger and it still does not turn on then try plugging it into you computer with a USB cable. If it turns on then replace your car charger. If it still does not work then your GPS either has a bad connection or something is wrong internally
Oct 24, 2010 | Garmin nuvi 255W GPS Receiver
It wont come on
Hello :
Have you charged it using the main charger? It's possible that just being connected to the PC isn't supplying enough power to get it properly charged. Try disconnecting it from the PC, plugging it into the charger and the charger into the wall and leave it for a while. Then try to turn it on. Do you have a car charger? Try that instead. If that didn't help , then I recommend you to replace the battery .
PLEASE RATE !
Apr 16, 2010 | Tomtom ONE GPS Receiver
Charger wont work. little red light on the
You need the correct cable for you car the one that you connect to the PC, they both look the same the PC lead wont work in the car you need the one that just charges in the car this normally has a 12V lighter socked at the feed end.
This and one other is the only SATNAV that has this two lead requirement as far a I know that is.
Jan 27, 2010 | Garmin nuvi 255W GPS Receiver
Forerunner 305 keeps beeping, turning on and off every 5 seconds
I think I had the same problem. You do not write if your device were connected to the PC. My device was, and I finally got the suspicision, that it died because the battery was so low, that it crashed when the PC polled it as an usb unit.
So, I connected the unit directly to the charger unit that came with the unit, and now it works. So, try to connect directly to your charger, when your battery is totally drained.
Sep 16, 2009 | Garmin Forerunner 305 GPS Receiver
Magellan 1400 gps does not turn on when connected to car charger. Tried several times but in vain? can you let me know how to fix it?
well it may not be able to be solved without expense.
Do you have an AC charger? if so try to turn iot on when its been connected to the charger for about 10 mins if it comes on when on AC then you will need to change the internal battery/s other than tjhat the circuit is damaged
some models do not have AC chargers
if this is new or under warranty make a claim ASAP as they go out of models so quickly they have a poor warranty system
Jun 23, 2009 | Magellan RoadMate 1400 Car GPS Receiver
Will not take a charge from either car charger and motorola port
YES the battery is sogged AC by passes low voltage circuit.9 battery) Get a new battery fitted and all should work again for you
Jun 19, 2009 | Garmin StreetPilot c340 GPS Receiver
Magellan Maestro Elite 4370 GPS Receiver Logo
301 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
