Question about Pioneer DEH-27MP CD Receiver w/ MP3/WMA Playback
Help i need the wire's that hook up to the sterio
  • 709 Answers
Re: help
Hi Bdowell,
I usually get my wires to fit the pioneer from Ebay. Several sellers actually offer the connecting wire harness and connector for Pioneers. A lot of the Pioneer models use the exact same wire harness and connector. use a little ingenuity and y search on ebay, you will probably find one.
Posted on Nov 08, 2007
0 characters
3 Points
Red wire need to be hot just when your key is on and the yellow wire is you auxiliary need to be hot all the time that is your memory and than you will have 8 wire they all have their pairs that is speakers and your blue wire wich is remote and amp if you have one
Feb 26, 2013 | Car Audio Receivers
Red light below cd slot behind faceplate and buttons on faceplate blink red sterio doesnot work
kinda sounds like not hooked up proper . more of the grounding and yellow wire
Dec 04, 2011 | Car Audio Receivers
Have Clarion DB148R cd car stereo but no wiring diagram
matching colors are the speakers, red it the accesory, needs to be hooked up to an alternating current, something that works with the ignitions, this will turn the sterio on and off, yellow is 12 volt or memory, constant power, blue is a remote wire for an amp. black is a ground wire and orange is normally an illumination wire, so when you dim your dash lights your stereo also dims.
Sep 04, 2009 | Clarion DB148R CD Player
I need to know how to install a pionear sterio into a 99 ford focas i have the wire harness and kit i just need to know how to dismount the factory sterio and what wires go where
You need the factory car stero keys, its like a u bracket one slides in either side then you just pull it out with them.
as your wires there colour coded :)
Feb 21, 2009 | Pioneer DEH-P6800MP CD Player
Wireing harness
What type of stereo?
Nov 13, 2008 | Clarion DRX9375R
red= accessories power on
yellow= power always on memmory
black= ground
blue white= amp switch this goes to amp
blue= power antenna
the other wires are speaker wires top is for the fronts
the bottom set is for the back speakers this is simple
suggestion if you dont know the wire hook up i suggest taken the wires and sterio to certified car sterio installer pay 5 bucks and have them splice the wires together for you so you dont screw up your vehicle wireing or your sterio this is crucial
Jul 07, 2008 | Clarion DXZ365MP CD Player
Install pioneer DEH-P6400 into 98 dodge dakota, just wont work :-(
Have you measured the 12v ignition and permanent supply?
Also check the earth.
You will need a tester for this.
Check the fuses
John w
Feb 13, 2008 | Pioneer DEH-P6400 CD Player
No Power to the unit
Hi perkyfridge,
You may have a problem with the faceplate connection not making good contact. Tell me what model Radio you have, that will help in determining what is wrong. Thank you.
Nov 22, 2007 | Pioneer DEH-P6400 CD Player
Pioneer DEH-27MP CD Receiver w/ MP3/WMA Playback Logo
140 people viewed this question
Top Pioneer Car Audio Receivers Experts
xxxxxx xxx
Are you a Pioneer Car Audio Receiver Expert? Answer questions, earn points and help others
