Plug either a powered monitor or amp and then speaker into one of the aux sends. Now adjust the monitor mix using the appropriate aux send pot on each of the channel strips you want to send to the monitor. Think of the aux send pots as faders for the monitor mix the same as the main fader for the ain mix.
SOURCE: hook up audio ut to audio in from mixer to computer
You just need a USB audio interface ... the outputs from your mixer are analog, which will plug into the right/left inputs on the audio interface ... and the audio interface connects to the computer via USB ... this is a very common way to do it ...
There are a lot of devices out there ... I'm using a Tapco Link.USB audio interface ... not too expensive ... you don't need anything fancy ...
Once you get the USB audio interface (by the way, if you are using a Mac you probably do not need to install any software for it) then you want to make sure your audio inputs are set to use it ... there are two ways to do this .. first way is right in the Cooledit software, if there is a place to tell the software what the input audio device is ... if this is not possible then change your systems general audio settings to select the USB audio interface for sound input.
That's it!
For audio expertise with conference recording and presentation and help with PA system problems, visit www.rexark.com
SOURCE: MAckie 1604 VLZ Pro Mixer,
The best way is to use a two-way crossover between the mixer and the amplifiers. In your case, the low output from teh crossover would go to the powered subs, the highs to the QSC. Use the crossover adjustment to set the frequency crossover point to get the sound quality you require.
Dan
Mackie 1604 ---> Crossover --- Highs ---> QSC --->Speakers
-----> Crossover --- Lows ---> Powered Subs.
Vito Vacirca Jr.
Pro Line Music
490 Lincoln Highway
Fairless Hills Pa. 19030
215-736-8055
Where do I plug the stage monitor cables into a Mackey 16 04 VLZ Pro
