Question about Kenmore Washing Machines
Washing machine fills with water then it goes out and keeps doing it
  • Kenmore Master
  • 8,220 Answers
Drain hose is set too low. Must be 30 inchs above the floor.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jul 01, 2009
Smart Drive machine on starting, water runs straight through into drain, thus not filling up
Most likely the water coming into the washer through the Water Inlet Valve could be siphoned out to the drain pump and out the drain hose because of an issue with the pump or plumbing. Is your washer overfilling?Is the washer detecting an overheat error? Observe carefully as to what part of the washing cycle the water is draining out. By watching the washer as it goes through its wash cycle, you can find out which part or error is causing the Washing Machine To Not Fill With Water and Keep Draining issue.
Washing Machine Will Not Fill With Water Keeps Draining How To Fix
Dec 03, 2017 | Washing Machines
Water keeps filling even when not in use
hi Jeremy.
Why does my washing machine keep filling up with water when not in use? Ensure that the waste pipe of the washing machine is higher at one point than the drum of the machine, this will prevent water running back into the machine. Normally this would fill the machine with dirty water. Or it could be a faulty water inlet valve, which will fill the machine with clean water.22 Sep 2007
why is my washing machine filling up with water when off ...
forums.moneysavingexpert.com/showthread.php?t=558300 Search for: Why does my washing machine keep filling up with water when not in use?
if you want to read up more then go to this link.
Washing Machines keeps filling even when not in use Google Search
Nov 18, 2017 | Washing Machines
My haiser washing machine keeps filling up with water when it should stop when enough water is in the drum
It sounds like you have a bad pressure switch. There should be a tube that goes from the drum to a switch that tells the machine to quit filling. If that switch works then the board might be bad. Hope this helps.
Apr 07, 2011 | Washing Machines
Washing machine never fills. The water keeps flowing and goes right down the drain... So it just stays stuck on the fill cycle... what do I do to fix it?
Have you checked the locatio of the drain hose?
Sounds like the drain hose is lower than the top of the tub and the water is running thru the pump and out the drain hose (water seeking its own level).
Mar 24, 2010 | Kenmore 98702 Stacked Washer/Dryer
2 problems 1st is the washer continues to fill with water when i put in a new load second is it wont spin
If the water keeps filling without cutting off, you either have a faulty inlet solenoide or your pressure hose and or pressure switch needs checking.
To isolate the acutal problem, start the machine on a new cycle. Change the water level to minimum or low before you start. Let the machine fill up. Keep checking the water intake as it fill up. Once the water level goes over the half way mark in your tank, if the machine starts its wash action then your pressure hose and switch are o.k. as they have signalled to the timer that the water level selected, has been reached.
However if the machine keeps filling up even though the wash action has started, then you have a faulty inlet solenoide/valve. Turn off water at the tap and get the valve replaced.
Ash
Oct 26, 2009 | General Electric WCSR2090G Top Load Washer
Washing Machine Keeps Filling with Water through Detergent dispen
This machine has a water valve that works on vaccuum from the tub. You will see a small clear hose that runs from the side of the tub up to this valve. This valve is adjustable to change the water level in the tub to desired setting on some machines, but if it goes bad, it will not shut off, thus overflowing the tub. Find this valve and replace it if adjustment does not work.
Oct 10, 2009 | Kenmore 24032\24036 Top Load Washer
Washing maching not filling with water
The problem is most likely the water fill sensor switch. If it is telling the machine that it is full, it will go right to agitate.
Apr 25, 2009 | Roper RAB2121KW Top Load Washer
Washer fills up than starts draining while in wash cycle
Hello , here is the fix-your drain hose is placed to low in the drain line in the wall, it can not be placed in water or it will siphon the water out of your washer into the drain pipe and it wont stop until it hits air. try pulling your drain hose up and out of the drain and get a zip tie or cable and tie it to one of the water valves by the drain pipe placing the end of the drain hose about 5-6 inches inside the drain pipe. Let me know if you have any other questions and good luck it will work.
Phil
Jan 28, 2009 | Frigidaire FLEB8200DS Top Load Stacked...
Washing Machines Logo
14 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
