Question about Marantz PM-15S1 2-Channel Amplifier
Marantz pm 15 s1 amplifier and marantz sa15 s1 Cd player
Hi,i have purchased marantz pm 15 s1 amplifier and sa 15 si cd player and i figured out that i couldn`t connect a optical wire from the CD player to the amplifier as the CD player has an coax and optical but the amplifier doesn`t have that slout.
Kindly help me with his problem.
i need to know if we can connect this optical cable and if so,to which slout in the amplifier.
There really is no point in  connecting the two components with an optical (=digital) cable, if you didn't want to use the SA-15s DAC- and analog output section you might aswell have bo bought the chiepest one you could find...
To get better sound than the SA-15s analog outputs can provide, you would have to spend a load of money (not as much as for the SA-15 but quite a bit) on a DAC - and the DAC would only work with CDs, you would still have to use the SA-15s analog outputs to listen to SACDs.
So in conclusion:
-Use the SA-15s analog outputs
-If you have other digital sources that you want to use - if you care about their sound quality - you can sell/return the SA-15s, buy the chiepest CD-Player you find (only look and feel matter) and spend the rest on a good DAC. (note: SACDs won't play on this setup)
I'm using a PM-15S1 with a DAC (Apogee Mini DAC, Studio-Equipment, nominal price ~1000$, got mine 2nd hand for 400€ ) myself. A DAC is usually the better choice over an expensive CD-Player - especially if you've got other digital sources (PC, ...) - but you'll probably lose a lot of money if you sell the SA-15, so think about it (IF you're still thinking about it, I realise that your question is 8 months old...)
anyway... have fun with the PM-15, it sure is beauty
Jan (Hamburg, Federal Republic of Krautistan)
Posted on Mar 17, 2010
Volume fluctuations
Does the volume fluctuate through speakers?
Feb 19, 2016 | Marantz Audio Players & Recorders
I have a Marantz turtntable, a Marantz CD player, an Eltax tape player and a Marantz amplifier with two Cambridge speakers, how do I wire them up please.
If you have a pure amplifier, there may only be one set of inputs, and one or two pairs of speaker outputs. The inputs are probably RCA plugs. Connect the CD or tape player to these. The speaker outputs are typically heavier binding posts or wire clamps. Each speaker should have one pair of wires. One for the 'Red' post, another for the 'Black' post.
If you have a 'Receiver' you will have several inputs to use and switches in front to select them. The CD and tape can be plugged into either tape, CD, or Aux inputs. (Not 'Phono') The speakers hookup is the same as for the amplifier.
You may also want to google the make-model of your amp to find a manual....
Mar 11, 2015 | Marantz Audio Players & Recorders
My Marantz SA-11S1 sacd player can't read many hybrid SACDs anymore. Do you recommend lens cleaning? Help please...!
hi,
just purchase a lance cleaning cd. It will be available in cd shops. insert it in the player. it will clean the lance. after cleaning insert the hybrid SACDs and watch is it reading. If not then the laser pickup unit of you player have some problem. You have to relapse the same.
ok
Mar 08, 2011 | Marantz SA-11S1
Will no longer play Red Book CDs - says either
just replace the ribbon wire of your cd player or check lense.by. jhuntech17
Oct 26, 2009 | Marantz SA-11S1
Marantz Pm-7200 left channel weak compared to the right
hmmm. Let's start by swapping the wires you are using for your speakers. Double check the wire connections first, then take the left and place iton the right and vice versa.
May 05, 2009 | Marantz PM7200 2-Channel Amplifier
The SA-1 cannot read CD and Display is off
lens is dirty ........clean the lens using the lens disk cleaner...........still problem continues the laser head is not picking up the disc...........need to replace laser assembly.......
Feb 04, 2009 | Marantz SA-1 CD Player
Can I remotely control speaker outputs on the Marantz PM 8003?
HI...
You need an 8 ohm stereo "L-pad"
Try partsexpress.com
or
mcmelectronics.com
Dec 21, 2008 | Marantz Audio Players & Recorders
Marantz PM 4000 has cut out
May be the problem solved here :
http://www.audiotoolers.com/ubbt/ubbthreads.php/ubb/showflat/Number/5316/page/1#Post5316
Nov 21, 2008 | Marantz Audio Players & Recorders
Marantz PM-48 connecting to TV
look on the back of the TV and there should be L/R audio outputs (white & red), connect this to a spare input of your amp via a connecting lead eg. AUX or any other input except PHONO.
hope this helps.
Oct 19, 2008 | Marantz PM-68 Amplifier
Marantz PM-15S1 2-Channel Amplifier Logo
715 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
