Question about Lightolier Ivory Galaxy Slide Dimmer Switch 600w X600-i
Ballast / dimmer compatability
I need to find acompatable dimmer for a Lightolier GLT142 PT UNV ballast, any ideas?
  • 152 Answers
I believe thats a magnetic ballast couldn't find it on the net... but anyway use a magnetic type dimmer for a magnetic ballast and an electronic flourescent ballast dimmer for the same..
Posted on Dec 06, 2009
Panasonic pt-50lc13 won't show picture. Blinks green when turned on can hear lamp clicking then goes off to red blinking for a few miniutes then shuts down to just red . Can u help me out please?
sound like your lamp is bad ...Panasonic TY-LA1000 Lamp Replacement...Ballast Repair Kit for Panasonic PT-50LC13 some time the ballast go bad as well to hear bouth part number one lamp and 2 ballast I hope this help you..
Nov 19, 2013 | Televison & Video
How to access ballast on pt-50lc13
The ballast is hard to completely remove--one plug all the way to the left as seen from rear and to the front, this does not really need to remove that.
The box is to the center and rear, unplug some plugs, screws and the box will come out far enough to replace the parts without removing the who thing from the set.
The large metal box with shields etc is the ballast.
Dec 22, 2012 | Panasonic PT-50LC13 50" Rear Projection...
Pt-50lc13 tv...where is the ballast located, and will a bad ballast cause the power button to flash red and nothing else to happen?
Hi, if you take off the back cover of the TV. Once you take the cover off there is a metal plate in the middle that has to come off. Behind the metal plate you will see a metal box with holes in it, thats the ballast board. It can be a number of things. It can be the ballast board or the power supply board. Take the back cover off and turn the TV on. You should hear the ballast board trying to fire. It will try at least 3 times before stopping. Is your lamp light on in the front of the TV.
Thanks for using Fixya, If you have any other questions please let me know.
Jan 25, 2011 | Panasonic PT-50LC13 50" Rear Projection...
Need to hook this up to a lutron eco-t528-277-2 ballast which only has a hot,dimmed hot and neutral
If I understand correctly, you have Leviton florescent dimmer
And you want to connect dimmer to Lutron ECO-series ballast
This is the ballast with 3 wires: Hot dimmed, Neutral and Hot
Is this your dimmer???? Has Black, White, Red, Yellow-red, & Orange
Here's how to do it:
Dimmer yellow-red is not used except for 3-way switch >> cap it off with wire nut
Dimmer orange wire connects to ballast Dimmed Hot
Dimmer red wire connects to ballast Hot
Dimmer white wire connects to ballast Neutral
Those are your wires going to ballast. As you can see, you need 3 wires going to florescent fixture
Next, let's focus on Dimmer:
Dimmer green wire goes to bare ground wire
Dimmer black wire connects to Hot from breaker box (we'll test for that next)
Finally the Dimmer white wire connects to ballast Neutral as discussed above BUT is also has to connect to Neutral from breaker box
This means the Dimmer white wire is connected to 2 wires >> one wire goes to florescent fixture and the other wire comes from breaker box
So which wires come from breaker box??
It should be a black and white wire.
Let's test to find Hot and Neutral that come from breaker box.
Mark your wires.
Disconnect all the wires and separate from each other
Turn on power
Use ordinary tester
Tape tester leads to wood sticks so hands stay away from electricity
Power is on
Test each wire to bare copper wire
When tester lights up, that is Hot from breaker box ... this wire connects to Dimmer black wire
Now, test the hot wire to each of the other wires
When tester lights up, that is Neutral wire ... this wire connects to Dimmer white wire, and also connects to Ballast neutral.
Connect one wire at a time, and it will work.
Oct 04, 2010 | Leviton Decora Light Dimmer Switch
Panasonic PT-LB10U do not work lamp ok ballast ok issue is with the power suplly that do not send 15v dc to the ballast need to fix the power supply it send 380 v dc to the ballast but do not have the 15 v...
You have to replace the transistor Q107 on the board ETXM519MBGB
this is pnp type but i can't find it on service manual.So if you don't like to make experiments replace the board.
Oct 21, 2009 | Panasonic PT-LB10VU Multimedia Projector
How to clean air filter on Panasonic PT-60LC13
could not find no filter after taking all panels off and I found out I needed a ballast
Feb 18, 2009 | Panasonic PT-60LC13 Television
Fluorescent dimmir
The dimmer you purchase needs to be compatable with the ballasts of the C.F. light. A compact flourescent potlight has a ballast, if your replacing incandescent bulbs with compact flourecent lamps
you still need a flourescent dimmer. Remember a ballast is like a transformer! If you compact flourecent fixture has a ballast by Lutron. then you need a lutron dimmer as there ballasts are not officially compatable with other dimmers, allthough I've seen them work. My advise is buy Pass & Seymour (Legrand) or Leviton.
Jan 21, 2009 | Pass & Seymour / Legrand DFB600-M 600VA...
Ballast problem on PT-40LC12
Sent me the serial number, and I can check for any re-call ...
my e-mail is <ultraman_s@yahoo.com>
Feb 01, 2008 | Panasonic PT-40LC12 40" Rear Projection...
Lightolier Ivory  Galaxy Slide Dimmer Switch 600w X600-i Logo
147 people viewed this question
Top Lightolier Electrical Supplies Experts
Steve
robert
Tom Chichester
Are you a Lightolier Electrical Supply Expert? Answer questions, earn points and help others
