Question about True GDM-23FC-RF Refrigerator Commercial
The beverages in my True refrigerator are frozen
    Novelist:
  • 112 Answers
Definitely a thermostat problem. Make sure that it is set on #3, make sure you have something in the box to provide a constant load (if you are worried about product freezing just put several gallons containers of water in there), set a thermometer on a shelf and let it run for several hours. Temperature should run 35-40f If it still freezes I recommend changing the thermostat. Not the easiest job on a True but the only real option. If it is too warm then raise the setting to #4 and run for several hours more and double check the temperature. It is normal for these box temperatures to "swing" quite a bit especially if empty. The thermostat actually senses coil temperature and not unit air temperature. Typically it cycles off when the coil reaches around 14f and then back on when the coil gets to around 38-40f.
Posted on Jul 07, 2009
Having trouble getting condenser motor out of unit, no access panels.
On this video You will find how to access condenser motor on true refrigerator.
Mar 24, 2015 | True GDM-7 Beverage Cooler
Can i use a beverage air mt27 as a freezer
doubtful but if you turn the dial to highest cold number what is the temp only you ca tell that
Mar 22, 2015 | Beverage-Air MT27 Beverage Cooler...
True TD-95-38-LT Beverage Cooler wont drain , cannot locate drain plug
Usually inside the compressor compartment, below that is the collection pan, blow it out with compressed air
Feb 01, 2013 | True TD-95-38-LT Beverage Cooler
Beverage air model UR30G, not cold, fan still running
check the thermostat for proper setting, evap could be frozen up, the condenser fan could not be running, unit could be low on freon. start check some items and let me know.
Jun 09, 2009 | Carrier Beverage-Air UR30GEFD Beverage...
Replacing temperature control on a True beverage cooler
Remove the doors, then the evaporator cover. Just be careful.
May 20, 2009 | True GDM-7 Beverage Cooler
Interior Lighting on True Refrigerator Unit
A starter may be located in the top area inside the cooler. Not all true coolers have starters. Check the connections where the light pins slide into. Also may need new ballast.
Jul 24, 2008 | True GDM-9 Beverage Cooler
True TBB-2 Cooler issue
BY to I take it yu mean top area inside cooler. If that is the case and yu are sure the drain is clear it could possibly be one of the following.
1: rusted/ corrodid evaporator drain pan
2: coil in cooler partially frozen
Jun 28, 2008 | True TBB-2 Beverage Cooler
True GDM-23FC-RF Refrigerator Commercial Logo
186 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
