Question about Dell Inspiron 9300 PC Notebook
I bought a inspiron 9300 loptop four years ago, and yestarday a thick vertical white line on the center appeared on my lcd. Is it time to replace my lcd?.
    President:
  • Dell Master
  • 1,314 Answers
Yes, that is an LCD failure and your screen will need to be replaced.
Posted on Jul 01, 2009
Thick vertical lines
Hi. I am sorry to tell you that your LCD screen has finished its usefull lifetime. This is a typical pixel-line problem. This problem usually can not be fixed, It is necessary to replace the LCD panel. Though sometimes some lines disappear when you do some pressure round the egde where starts the line. To replace the LCD panel is usually as expensive as 80% of the Total price of the Device.
Apr 20, 2010 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
White vertical line through laptop screen
The cause is a failure of the LCD, and you can fix it by replacing the LCD.
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=Inspiron+5160+LCD&_sacat=See-All-Categories
Instructions are here
http://support.dell.com/support/edocs/SYSTEMS/ins5160/en/SM/display.htm#wp1105699
Mar 29, 2010 | Compaq Presario M2000 Notebook
Numerous, bright, multi-colored vertical lines on 9300 screen
Try taking out the Ram memory first one stick at a time. Sometimes when Ram goes bad or overheats, it first affects the display. If that is not the issue, here is the link to your service manual.
http://support.dell.com/support/edocs/systems/ins9300/sm/index.htm
Oct 09, 2009 | Dell Inspiron 9300 PC Notebook
I bought a Dell Inspiron 9300 in July of 2005, a thick white vertical line appeared on the LCD two days ago. Given the fact that there are too many custumers that acquired this model in the past, and have...
hi
this problem is very common with your model.
this problem somtimes occur due to malfunctioning of this display module.
dell takes the responsibility of all such manuacturing defects.
call the customer care and they will replace your display or motherboard whichever is required for free if you system is under warranty.
if you find the solution helpful plz rate me carefully.
Jul 02, 2009 | Dell Inspiron 9300 Notebook
I have laptop dell inspiron 9300 it 17 sreen , it has a white verticle white line about on the middle about inche 1 1/8 wide hohow to fix? thank you...very much
Unfortunately, there is no way to fix it.
This line called "Tab Separation" of LCD.
You'll need whole new LCD display.
Very very common problem.
Apr 29, 2009 | HP Pavilion zd8000 Notebook
I have a Dell Inspiron 9300
if there is white line in the middle of the screen then first of all turn off the laptop and disconnect the ac adaptor and take out the battery and press and hold down the power button without the power cord and the battery for one minute and then turn on the computer with power cord and the battery and then check it out and still after that if u get it then check it out with the external monitor and if u get a good display in the external monitor then replace the lcd,but make sure that the screen is not broken from inside which u cannot touch and feel it.and if u get a good display in the external monitor then definately replace the lcd screen....good luck
thanks
Dec 27, 2008 | Compaq Presario M2000 Notebook
Yellow vertical lines on the screen of my DELL inspiron 9300
The pixels are shot - common for lower priced LCD monitors. Once it starts, it will continue. Theres no inexpensive fix for it - time to retire the Compaq
Nov 28, 2008 | Compaq Presario M2000 Notebook
Vertical lines in my laptop screen
Try connecting an external monitor to the Dell Inspiron 9300 and see if the vertical line is also present on the monitor. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor also displays the vertical line, then your problem is with either the video card or motherboard located inside your laptop.
Not sure if the Compaq Presario has an external monitor plug, but if it does the above procedure can be applied to that one as well.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 19, 2008 | Dell Inspiron 9300 Notebook
Many times over years of use the thin canle that connects motherboard to monitor becomes loose very slightly but enough to create these type effects on screen.First easy test would simply be hooking up another monitor to rule out video card.Next would be looking up how to disassemble the plastic trim to expose the lcd cable then carefully disconnecting it then reseating it.If problem still exists wiggle the lcd cable see if it affects lines on lcd display if so then you probably need new cable if not then most likely an lcd screen.
Screens can usually be replaced in about 45 minutes by avg.person.
Feb 13, 2008 | Dell Inspiron 9400 Notebook
Dell 9300 screen
http://direct2dell.com/one2one/archive/2007/04/09/10675.aspx
This is a known factory defect. Dell has a recall on it for Inspiron 9300 shipped between Nov 2004 and Nov 2006.
I just called Dell Tech Support (1-800-624-9896) to get this replaced and they are fixing it free of charge because I bought mine in December 2005. They are sending me a postage-paid box to ship back the laptop (remove the battery before sending it back to them, per instruction).
NOTE: Not all Tech Support people are well trained. The first time I called earlier today (Nov 21, 2007), the tech said (incorrectly) that only units shipped between Feb and March 06 are covered and denied that Dell would cover it for me. I was fuming mad.
Then I surfed around and found the link above which is Dell's official response. I called Tech Support back and got a better tech person. Moral of the story >> if you're certain your computer is covered per Dell's official statement, don't let the tech guys push you around. Email them the link from their own site if you have to. Better yet, just hang up and call back and hopefully you'll get someone who knows what he's talking about.
When you call Tech Support, have your Express Service code ready. They use this number to loop up whether or not your laptop is in the recall group. This number is at the bottom of your laptop on a long skinny oblong white tag.
Nov 20, 2007 | Dell Inspiron 9300 Notebook
Dell Inspiron 9300 PC Notebook Logo
380 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
