Question about Texas Instruments TI-84 Plus Silver Edition Graphic Calculator
TI 84 Windows range problem
I cant input negative numbers into my xmin and ymin. I press the window button type in -5 in the xmin and press enter and it gives me a ERR:SYNTAX message. my xmax is larger so I dont understand why it wont let me input any negative numbers.
  • Anonymous Mar 17, 2014
    I have a question about the syntax error.I first type 2.4 / 3.14159... and get 7.639 x 10 ^-1. Then I tried typing ANS x 10^8 where the 10^8 comes from the x10^x button and it is giving me a syntax error, I don't know why?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 88 Answers
I think you are using the minus symbol instead of the negative symbol (located below the 3).
Posted on Aug 06, 2009
It wont let me graph. i keep getting an error message err: window range.
You need to press the "window" button located at the top of the calculator, then change the Xmin,Xmax,Ymin, and Ymax to values that your graph will fit in.
Apr 28, 2011 | Texas Instruments TI-84 Plus Calculator
How do I change the dimensions on my ti-84?
You probably mean window dimensions. If that be the case
Press [WINDOW] key.
Use cursor to scroll down the lines. Change Xmin, Xmax,Ymin, Ymax, Xscl, Yscl. Make sure that Xmin is less than Xmax, and Ymin is less than Ymax.
Sep 19, 2010 | Texas Instruments TI-84 Plus Calculator
How do i fix the window numbers on my calculator
You can try to reset the calculator: In so doing the default configuration is restored. If that works for your graphs why fiddle with the setting?
Ok to reset calculator (do not worry I will tell you how to change window dimension):
Press [2nd][+] to access the (MEM)ory management.
Press [7:Reset][2:Defaults] [2:Reset]
The window dimension will be restored.
To change dimensions
In main calculator screen press the [WINDOW] function key
Enter the value of Xmin. If negative use the change sign key (-) under key 3
Enter Xmax value. Make sure that Xmin is less than Xmax.
Leave the Xscale at 1
Enter Ymin. If negative use the change (-) key
You can leave the Yscale at 1, Xres at 1.
You can change the DeltaX but if you take too small a value your graphs will take long to be drawn.
If you ever get a problem, just press the [ZOOM] function key and select [6:ZStandard] it will restore the default dimensions.
Jul 25, 2010 | Texas Instruments TI-84 Plus Calculator
I insert the problem in the Y= button but when I click on graph or trace the 1.QUIT display keeps coming out...What do I do t fix this?
To graph functions, always deactivate the statistical plots
  1. Press [2nd][Y=] to access (STATPLOT) then press [4:PlotsOff]
  2. Command PlostOff echoes on main screen.
  3. Press [ENTER], calculator answers Done.
  4. Open the [Y=] editor to enter your function and
  5. Press [GRAPH].
  6. If you do not see any graph,
  • press [ZOOM][6:ZStandard] or
  • adjust the window dimensions by
  • pressing [Zoom] and
  • setting the Xmin,Xmax,Ymin,Ymax values
  • making sure that Xmin is less than Xmax, and Ymin is less than Ymax.
Feb 23, 2010 | Texas Instruments TI-84 Plus Silver...
ERR: Window Range
Press ZOOM and select Zoom standard (ZoomStd).
Alternatively, press the WINDOW key to access the window range setup
Set Xmin=-10
Xmax=10
Ymin=-10
Ymax=10
These are the standard dimensions of the window.
You can change the dimensions as long as Xmin is less then Xmax, and Ymin is less than Ymax. Do not make Xres close to Xmax-Xmin.
Jan 10, 2010 | Texas Instruments TI-83 Plus Calculator
How do i reset my window settings for graphing
Hello, If by reset you mean revert to the default settings, press [Zoom][6:ZStandard] If on the other hand, you want to play with the window dimensions press [WINDOW] and change the values of Xmin, Xmax,Ymin,Ymax. Make sure that Xmin Less than Xmax, Ymin less than Ymax. If domain is positive set Xmin=0., If range is positive set Ymin =0. Hope it helps.
Nov 01, 2009 | Texas Instruments TI-84 Plus Calculator
Problems seeing graph on calculator....think it has something to do with limits set on window....what do I do
I take your word for it. If graph is out of range you should zoom out.
But first try [ZOOM][6:Ztandard]. If you still see nothing, press [WNIDOW] and set XMIN=-100, XMAX=100, YMIN=-100, YMAX=100.
Otherwise you must know a few things about the behavior of the function you try to hraph
1. If X is always positif, set XMIN=0
2.If X is always negative, set XMAX=0
3. If Y has only positive values, set YMIN=0
4. If Y has only negative values, set YMAX=0
You can also calculate Y for X=0. Let Y(0) be that value. Then you try to have the Y-Values centerd around it: YMIN=Y(0)-10 and YMAX=Y(0)+10.
Hope it helps.
Oct 22, 2009 | Texas Instruments TI-84 Plus Calculator
I don't have a problem with my calculator but I need to know on how to put in values for graphing example Xmin=, Xmax=, etc.
Xmin must be less than Xmax; Ymin must be less than Ymax. If your X variable takes only positive values you can set Xmin=0; if you want to graph y=X^2, you know that all y-values are going to be positive, so there is no need to waste screen real estate by putting Ymin negative.
It is like taking a picture with a camera. You point the viwefinder where the action is.
My suggestion is to set the default values Xmin=-10, Xmax=10, Ymin=-10, Ymax=10. Then look at the graph and locate the part that interests you more and focus on it by zooming in. Your knowledge of the general behavior of the function will help you determine what is worth looking at.
Hope it helps.
Sep 30, 2009 | Texas Instruments TI-84 Plus Calculator
How to set the window?
Press [Window]
Set the values of Xmin, Xmax, Ymin, Ymax.
If the x values that the function takes are all positive, you may set Xmin =0. If the values of the function are all positive, you can set Ymin=0.
If you are drawing a sine or a cosine function, you know that the function values are between -1 and +1, so you cant restict Ymin an Ymax to say -1.2 and 1.2. Similarly if you draw trigonometric function no need to have a range of X values between -10 and 10: the function being periodic you can restrict values (in radians to -pi to +pi, ) or to -90 to +90 degrees.
You set the limits of the window by making use of your knowledge of the functions you are drawing.
Hope it helps.
Sep 19, 2009 | Texas Instruments TI-83 Plus Calculator
I can't graph on my ti-84 plus silv. edition
More than likely, you've put in a number in the xmin or xmax that is not correct. Example....you put in an xmin of 10 and an xmax of -10 which would be backwards. This could also happen in the ymin or y max.
The easiest way to fix this is to press zoom 6 which wil get you back to the default graph of xmin of -10, xmax of 10 and ymin of -10 and y max of 10.
If you can't see your graph on this screen and need to change the window, just be sure the number in the min for both x & y is smaller than the number in the max. You change your window size by pressing the window button.
Aug 13, 2009 | Texas Instruments TI-83 Plus Silver...
Texas Instruments TI-84 Plus Silver Edition Graphic Calculator Logo
496 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
