Question about Kenmore Washing Machines
Not spinning during rinse. tank fills up, it aggretates fine, then come spin time it sits there. Check the lid switch. its fine. took off the h2o pump to drain the water out, remove the motor to check coupling its fine, check the brake release (looks fine I was able to tunr it by hand, not sure what to do next............
  • pfrasquieri Jul 02, 2009
    you mean the clutch? what am I looking for?
  • Kenmore Master
  • 8,220 Answers
Remove the coupling endpiece on the transmission. I bet it is wallowed out.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jul 01, 2009
I have an Amana Top Load Washer Model Number ntw4800vq1 The washer shakes violently during the Spin Cylce. It will walk across the floor. I took the console off and removed the outer shell. I checked...
Hi
for the question of water comming in the spin cycle, yes its normal we call it a spray rinse. For the shaking check your leveling and also make sure that the back leveling feet when lifting back of washer up and down that the foot mechanism is functining.
Hope this helps
Mar 27, 2011 | Amana Washing Machines
Whirlpool top load washer no low-speed agitation. The unit fills, starts the wash cycle with normal agitation, but after a few minutes it just sits there soaking until the it's time to drain/spin. Drains...
Either the wire going to motor for non working speed is loose or damaged, or motor is bad. It could also possibly be timer not sending power to motor for that speed.
Sep 27, 2017 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer will not agitate/spin.
The lid switch is fine. The timer needs to be replaced.
Jul 22, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Will not spin on any rinse cycle
Hi, This washer does not have a belt. While the washer is agitating, if you lift the lid will it stop? Some models will agitate but not spin if the lid is up. It sounds to me like the lid switch might be going bad.
If you will get me a model #, I can look this up for you and give you a better idea.
Vic
Jul 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Spin/drain cycle won't start
If the timer gets to the rinse cycle and stops,
Check the lid switch for continuity. If no continuity replace the lid switch.
If the timer continues through rinse and spin without doing either, replace the timer.
May 21, 2009 | Kenmore Washing Machines
Tube doesn't spin during rinse/spin cycle.
It needs a new clutch. Call a repair technician.
Nov 19, 2017 | Washing Machines
I have a Roper washing machine that will fill with water, agitate, and stops. I replaced the lid switch assembly and tried it again. Same thing, but one step farther. It went past the agitate and...
The black dust is from the motor coupler. It is normal to have some under the unit. If it stops completly and you chaged the switch check the lid adjustment if the lid is loose it might not make the switch all the time.
Apr 24, 2008 | Washing Machines
Washer will not Spin during SPIN CYCLES
check the lid switch on the washer its below where the tab on the washer lid that goes down in the body of the washer there two screws at the base of the control panel back these out and raise the panel you will see a connector coming from the washer disconnect it and put a jumper wire where it goes to the control panel turn it to spin pull out the knob if it spins replace the switch if it doesn't reply to me and we will go from there
Jan 30, 2008 | Kenmore 22422 Top Load Washer
Kenmore 20903 Top Load Washer Problem: No agitation
the lid switch is fine. check wiring and motor connections.it could also be a bad timer
Dec 27, 2007 | Kenmore 22422 Top Load Washer
Agitator Not Working
check your motor coupler, lid switch
Nov 08, 2006 | Hotpoint VBXR1090D Top Load Washer
Washing Machines Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
