Model 135202
SOURCE: need a manual for yard machine model# 135202
Hello:
A Breakdown should Assist youin Assembling the Tank and Carburetor. If the Engine Breakdown is Not at this Site, then Send me the OEM, Model and Type/Spec Numbers Off the Engine, Please. With these I can Locate the Correct Manuals and Better Assist you.
You can View a Breakdown/IPL of this Unit at this Site Addy, http://www.buymtdonline.com/webapp/wcs/stores/servlet/Home_YardMan_10101_19502_-1 and Select the Shop Online Parts Look Up. Then Select the Model Tab. Then Select the OEM (MTD) and Enter the Model Numbers. Then Double Click on the Model in the Results Area. Now you can Select the Section of the Unit you Wish to View.
You can Contact MTD at 1-800-269-6215 at during the following times and Request/Purchase a Manual: Monday-Friday 8am-5pm and Saturday 11am-3pm EST. (SEASONAL HOURS MAY VARY).
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
SOURCE: I need a diagram for the carburetor linkage on a
go to partstree.com and get a diagram for this.
hope this helps you.let me know.if you cant find it ill get you one ok.let me know
SOURCE: I have a MTD Yard
If you go to this webpage:
http://www.mtdproducts.com/webapp/wcs/stores/servlet/OwnersCenterView?storeId=10500&catalogId=20500&langId=-1
....you can enter your model number and serial number to download the manual.
SOURCE: i have a mtd yard
remove the sediment bowl off the bottom of the carburator and dump out any moisture,then replace it and see if you can keep it running with the choke partially on,if so then you have a lack of fuel due to a dirty carburator,if this doesnt help,the gasoline cap can get bad and go shut and vapor-lock loosen the cap and also try this
