Question about Reddy Heater-30-55,000 BTU Variable
Reddy heater r35
I have a Reddy Heater R35. There are two wires going to the ignitor; one red and one white. Does it matter which terminals each of the wires go to.
  • 625 Answers
No it doesn't - the ignitor goes to printed circuit connectors on your control board. the ignitor operates on 120 volts ac. for repair parts on any reddy heater go to www dot desatech dot com
Posted on Nov 10, 2007
  • Gene Haynes Jan 17, 2014
    Avery is full of BS
Have fuel but no spark at the spark plug 35000 btu
The electrodes might need cleaned. I am attaching a link, please check out the FAQ section, then scroll down and click on FAQ for spark plug heaters. I hope this helps. Reddy Heater Parts Sales Online Mr Reddy Heater Parts Master Heater Parts...
Jan 21, 2018 | Reddy Heating & Cooling
Reddy heater starts fuel sprays and ignitor glows then it shuts down without starting flame
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Jan 28, 2011 | Reddy Heater-30-55,000 BTU Variable
Need to order an ignitor for the Reddy Heater Pro 155. It has a white case with red lettering.
Try this link:
I have a tip at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters which will solve your problem and get you the parts at the best price.
There are some other adjusting tricks and things-- let me know if you need more--
Mack B
Jan 20, 2011 | Reddy R155D Utility Heater
My reddy heater ignitor button will not click
No click at all? Replace the ignitor. Click but no spark, the wire broke off the sparker.
Find a replacement where you got the heater or at any full service gas supplier (dont forget the guy that sells BBQ equipment)
Jan 03, 2010 | Reddy Heater-30,000 BTU Propane Forced-Air...
Need help with the wiring on the reddy heater 110 btu
CIRCUIT CARD-
-Photocell blue wired go to two terminals marked BLUE PHOTOCELL (any order)
-Motor red wire plugs onto terminal marked MTR MAIN, motor white wire plugs into terminal marked WHITE MOTOR.
-potentiometer (thing with knob) two white wires plug into terminals marked TEMP SEL
-Black wire from switch to terminal marked L1 BLACK
-White wire from power cord goes to terminal marked N White
-Ignitor (used to be yellow wires) goto terminals marked IGNITOR and IGNITOR RET (any order)
OTHER-
-White wire from power cord goes to switch terminal marked 3A , other pigtail of the white wire goes to board as described above.
-Black wire from power cord goes to swtich terminal marked 4B
Nov 14, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy heater model 28725
propane heater uses a hot surface ignitor. this operates off 120 volts and glows red/orange when actuated. it stays lit throughout the heater on operation.  on the backplate of the combustion chamber is a high limit with two wires coming off it.  these two wires connect to the spade connectors on the flame detector cappillary.  Once you establish a fire, the flame detector generates a 750 millivolt signal which is applied to the pilot/main valve assembly.  My diagram will show this. 1fa8284.jpg
Oct 12, 2007 | Reddy Heater-30,000 BTU Propane Forced-Air...
Reddy Heater-30-55,000 BTU Variable Logo
546 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
