Question about Carrier Heating & Cooling
Carrier model 50yq036310 manufactur date 07-1983
Carrier model 50yq036310 manufactur date 07-83 replaced capacitor and new motor for moving air through the duct work. The unit internal cooling fan motor is shutting down and the unit stops operating. I may need a replacement motor complete with factory made onto bracket. where can one be found on such an old package central system.
  • 143 Answers
SOURCE: GE Central A/C Unit about 30 yrs old; condenser fan stops after a short time.
I gather that it is the outdoor fan motor that runs a bit then stops.
Fan motors that stop by themselves are overheating and going into self-protect. The fact that you replaced the motor and capacitor opens up a whole world of "which wire is in the wrong place". I could do this if I could see it, but I can't see it. You're probably going to wind up calling a service man to sort out the wiring.
Posted on Jul 25, 2008
  • 148 Answers
SOURCE: UNIT RUNS AN EXCESSIVE AMOUNT OF TIME AND AIR IS
DOES THE HOUSE FEEL DRIER IF IT IS 80 OUTSIDE WITH ALOT OF HUMIDITY THE UNIT WILL RUN FOR A LONG TIME TO REMOVE THE MOISTURE(HUMIDITY) OUT OF THE HOUSE BEFORE TEMP DROPS DRAMATICALLY IS THERE WATER COMING OUT OF THE DRAIN PIPE OUTSIDE
Posted on May 03, 2009
  • 116 Answers
SOURCE: My ac fan went out on a carrier ac unit. Need wiring help
use a seperate capicitor for the fan only pick up 1 leg of power from common side of the compressor cap and the other from the contactor or the board in a heat pump situation
Posted on May 11, 2009
SOURCE: Outside AC unit fan is moving, but no air is blowing out of it
might you have physically installed the fan blade upside down?
Posted on Jun 27, 2009
jumptrout51
  • 3361 Answers
SOURCE: I have a GE central air conditioner model
If you are talking about the indoor fan it is probably a bad capacitor. Replace the fan motor capacitor. And YES, if the fan motor needs replacing too, you can DO-IT-YOURSELF.
Posted on Jul 05, 2009
My carrier model # 48ss-036100331 induced-draft motor will not start
On some of those inducer motors there is also a capacitor in the blower compartment on the left side of the burner section. It is possible that if you have 230v coming from the board CM terminals and if the motor is new maybe you have a bad capacitor in the blower section. Follow the wires to the capacitor and check microfarad reading to that capacitor. Caution there maybe 2 in this area but one is for the indoor blower motor and the other will be for the draft motor. The blower capacitor may be somewhere between 10 or 15 mfd but the draft inducer capacitor will be around 3 mfd. hope this helps
Feb 19, 2016 | Carrier Heating & Cooling
Carrier model 38cks air conditioner compressor fan
sounds like you need to replace the condenser fan motor. It has a thermal overload inside the compressor and will shut it off before it harms the compressor. The only way to get it to reset is cool down the compressor with a water hose.
Sep 04, 2014 | Heating & Cooling
Connecting replacement fan motor in HP condenser
What is the model number of the heat pump? What is the voltage that you are dealing with?
Nov 26, 2013 | Carrier Heating & Cooling
How to connect a fan motor for a 7 ton carrier ac unit
7 ton, sounds like a commercial unit, if this so could be three faze. is this fan for cooling the outside condensor coils or the blower motor for moving air through the inside duct work
Feb 02, 2011 | Heating & Cooling
My Carrier 43B00HP - 1 is not blowing cool air. The fan is working but the cool air isnt coming out. If you turn it on and leave it on for awhile it turns off by itself
Please check your compressor whether it takes correct amphs. Due to weak in capacitor and also less rpm of fan motor the compressor gets overheated and it turns the unit off. If capacitor weak change it. If less rpm on fan motor change fan capacitor or fan motor.
Dec 12, 2010 | Carrier Heating & Cooling
Carrier Furnance Fan / Blower Doesn't Start (Model 58GP-125-GA)
sounds like a bad capacitor usually screwed to the blower housing (round or oval shiny can)
this gives the motor a kick start)
depending on the motor there is usally two brown wires that go to it
check the mfd rating on it probably 5mfd and replace it with a matching one
its a very inexpensive part
Aug 02, 2009 | Carrier 38CKC036 Air Conditioner
Heating & Cooling Logo
201 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
