Question about McCulloch 26cc Gas Blower Mcb3208
Cant figure out where fuel lines go on mccullogh chain saw
Mccullogh fr4618 where do fuel lines go? They are all rotten. I got a new pump bulb and fuel lines but I dont know where they go. Please help Thank you very much
  • 1,305 Answers
Fuel lines: one comes from the tank...has a filter in side the tank...runs up to the intake of the carb... you can tell by hooking up the lines to the carb, and put one into a gas supply... press the prime bulb... if it pulls gas, thats the one to hook into the tank...if not it 's the other... there should only be two lines a fuel supply and a return pressure line. Clean the air filter while you've got it apart....
k
Posted on Jul 01, 2009
Where is the check valve on the fuel primer bulb on a poulan chain saw , filter . bulb or carb.
in the block that bulb is attached to or in the bulb base if det off the carby
Apr 28, 2018 | Poulan Garden
Need to replace fuel lines that is rotten
Hi randy waldrop...
Here is the fuel routing for chain saws
Please rate me
Bud
Sep 29, 2012 | Craftsman Sears Chain Saw Manuals Model...
I HAVE TO REPLACE FUEL LINES ON A POULAN MODEL 2450 CHAIN SAW NOT SURE WHERE TO HOOK THE LINES TO AS THE OLD LINES WAS ROTTEN AND CAME OFF THE POSTS OR LOCATIONS WHERE THEY WERE HOOKED
Sorry to hear of your predicament. It's upsetting but not that hard to fix.
You'll have to drain the gas out of the tank first and toss it if it isn't fresh. Remove the filler cap. Take the cover off the saw and possibly the air filter if it's in the way.
Turn the saw upside down and shake the fuel filter to the opening of the gas tank (it's inside the tank) and grab it with a needle nose pliers and pull it out. If the line was that bad, you'll want to replace the fuel filter also.
You'll need to get new fuel line, which is clear tubing. You'll need about 6-8 inches of tubing.
Attach the new line to the fuel filter and feed the line into the gas tank and through the hole in the bottom. Pull it all the through to the interior of the saw. Feed the line around to the small metal tube on the carburetor. Before you connect to the carb, cut the excess line off.
If your saw has a priming bulb, connect the line to the fuel entrance on the bulb.
I hope this helps. If it does, I'd appreciate a 4 thumbs up vote. Thanks,
Handie Andie
Apr 15, 2011 | Poulan Garden
How you put the prim bulb on a fr4618 chine saw
If you buy the new one first.You will see that they just snap in and out.It will say on the back of the bulb carb and tank in very small letters.Reinstall the fuel lines just as it says.You need to unbolt the pull rope side cover to get to it.Don't worry nothing will fly out at you.
Mar 08, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
I'm trying to replace the fuel lines on the primer button of a small McCullough chain saw. The old ones had dry-rotted and fell off, and I couldn't determine which line goes where. My first configuration...
The primer is just a small pump--it is supposed to draw fresh fuel through the carburetor and expel it back into the tank. There are also just two lines on the carburetor--the upper one should go straight to the fuel tank and filter, the other goes to the intake side of the pump. Just pick a port of the primer (remove the other line for the moment), and try to pump fuel into the bulb (make sure the bulb is not decayed as well)--it should fill with fuel if you have the correct connection--if not, just place the line from the carburetor on the other primer port and try to pump again. If still no fuel, something is plugged in the carburetor or the fuel filter. Hope this helps!
Nov 10, 2010 | McCulloch 16" Electric Chain Saw 35 HP
Trying to put back together a poulan chainsaw and cannot figure out where the tubes go into the carborator
The line from the tank that has the filter on it's end is the main feed to the carburetor and goes to the upper port on the carburetor. The lower port on the carburetor goes to the primer bulb which is supposed to pull fuel from the filter to the carburetor and out to the primer, then it outputs excess fuel back into the tank. When the lines are connected correctly and fuel in the tank, pump the primer--it should begin to fill the bulb with fuel after several pumps. Usually, the primer ports are found by trial and error until it works. Hope this helps!
Jun 13, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Chain saw, there is a line from primer to the carb, then what? I cant tell if coming out of the carb it goes back to primer or in the fuel tank? Then should there be a line from fuel tank to the primer?
Similar to this, typical fuel system.
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly. HTH
Lou
Dec 19, 2009 | McCulloch 10" Electric Pole / Chain Saw
I have a 3516 chain saw mod22-600035-18 Mcculloch the fuel lines
I wish I could help. There are no parts available, there are no Exploded parts lists I've found a link to. These are Chinese chainsaws with the McCulloch name. They ARE Chinese chainsaws and I'm disappointed in Mac. Most mechanics won't touch them. We can provide no more help with this saw. Sorry
Lou
Poulan or Craftsman gasoline chainsaws are reasonably inexpensive, parts are available, and given a little TLC perform well.
Jun 10, 2009 | McCulloch Garden
Fuel leak
hi jaspunkin
check the fuel line,tubes and the integrity of the fuel tank,
regards savumihai71
Nov 21, 2008 | McCulloch Garden
McCulloch 26cc Gas Blower Mcb3208 Logo
582 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Matt Olenzek
Matt Olenzek
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
