Unit runs for about 5mins then shuts down,Can reset by switching off at mains and restarting but agin only lasts about 5
    Scholar:
  • 86 Answers
Have you clean the condenser fins or clean or change the filter. try that.
Posted on Jul 02, 2009
C-3725 trouble code
The fusing unit in side machine has reached a very high temp. This is the unit which fuses the toner to the paper the hot part upper right hand side of the machine. to reset follow:
Utility
1.Power off the machine using the main power switch inside front door leave sub power switch on that's the one on the op panel side.
2. Hold down the Utility/counter button.
3. Power on using main power switch and close the door.
4. wait for screen to show trouble reset touch trouble reset chk for OK
5. turn off main power switch, wait 10 seconds then power it up again. it should restart and go ready to copy. if the code comes back do not reset the machine again. It is informing you there is a problem get it looked at.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 01, 2014 | Konica Minolta KONICA BR BIZHUB C451...
Macerator works only for 5mins every 15mins. But won't work during the 15mins.
Well it is working in a stinky environment! Just think, without it you could be hand chopping all that "stuff" up!!!
http://www.ehow.com/info_12169188_saniflo-system-work.html
Sounds like you have a sticky switch inside the macerator.
http://www.saniflo.com/products/index/show-product/lang/en/type/part/id/54
As this is a messy piece of plumbing, I'm going to recommed that you take it out of the system and take it outside in the yard, away from the house and give it a good hosing out. It is possible that some gunk has clogged up the pressure chambers vents and this is causing the float or whatever mechanism in there to be stuck on. Flush it as much as possible before you disconnect it.
Sep 04, 2012 | Saniflo SANIPRO Macerating Pump
LG Air Conditioner LST182V-4
It may cause it to shut down if it's a safety thing, but it sounds like the compressor's faulty to me.
May 16, 2012 | LG Heating & Cooling
Powermax xp8500e will start and run about 5mins quites restart and run about 5mins quites and won't restart (no fire at sparkplug)
most of this generators have a shut off for low oil, so check your oil level to see if this is the problem
Sep 15, 2011 | Watts Onan Portable Generator - 4000 ,...
At the last use the DVD player was plpaying and someone' shut it off. It now won't open, and it kept saying no disk found so I thought it was empty. BUT one disk of a series of 3 is missing. I...
You can try 1 of 2 possible options;
1) while the unit is in standby (showing clock only) - on the main unit (not the remote) press [STOP] and [CH UP] button together - for 5 - 10 seconds - this should force the tray to eject any discs that may be in it.
or
2) you can do a hard/power reset - the hard reset - press and hold [POWER ON/OFF] button (again on main unit) for 10 - 15 seconds (this helps if the unit freezes or fails to respond to remote commands).
Other things you can try include; press and hold [CH UP] and [CH DOWN] buttons on main unit (again while unit is in standby) together to reset to factory defaults.
Or you can switch off at the wall, and wait an hour, then switch back on.
Let us assume a disc IS in the tray; try the above suggestions first before going down the expensive and heartbreaking road of either submitting this one to a service centre or buying another unit.
Mar 16, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
My toshiba Satellite A215-S7422 System unit, dose not shut down until the batries runs down.
1. It means the normal shutdown process is not working!
2. Try to press the "Power" button continuously untill the system shuts down!
3. Restart the system.
4. Press F8 key to get the advanced booting options.
5. Select the last option "Last Known Best Configuration"!
if it don't helps tell me...tc! :)
Jan 05, 2010 | Toshiba Satellite Pro A210-EZ2202X...
Rinnai Energysaver 1001FT, ignites, blows 5mins then shuts down.
Sounds like it is reaching high limit...either the filters on the back are plugged, or the manifold pressure isn't adjusted properly. IF the exhaust were plugged on the unit, it wouldn't fire at all, since it has a pressure switch to verify vent flow. The slightest blockage, the unit will lock out to prevent damage to the unit.
Jul 07, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
My Panny AE700U shut down & won't restart
HI there
This is a faulty Mainboard that will need either repair or replacement.
If a Projector starts playing on and off tricks I have found it to be 99% of the time a faulty Mainboard.
Apr 13, 2008 | Panasonic PT-AE700U Multimedia Projector
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
