Question about Nikon N6006 35mm SLR Camera
Sync speend Does anyone know the correct sync speed used for this model. I can't seem to find it after searching the manual through and through. Thanks!
  • 37 Answers
The sync speed varies depending on what you want to shoot and the flash you have. You can sync up to 1/250 usually.
Posted on Jul 13, 2009
    Brigadier General:
  • 3,006 Answers
1/125 of a second, according to Nikon, but I've found on my N8008 that using 1/60 is more reliable.
if you use one of Nikon's dedicated Speedlights (SB-24, SB-23, SB-22, SB-20, SB-18, and SB-16B) then they set the synch speed automatically.
Posted on Jul 03, 2009
Indoor picture are dark when using flash---seem like the flash and the camera are not in sync minolta 7d digital camera
If you are in Manual Mode and you set your shutter speed too higher (ie above 250th sec) the shutter blind passes over the sensor when the flash goes off causing a dark section in the photo. Lower the shutter speed to get a better sync. Some camera's default sync speed is 1/60th of a second and sometimes user adjustable.
Remember the longer the shutter speed, the more light will register in the photo. Also boosting the ISO will help extend the flashes range and also record more ambient light for a more pleasing and balanced photo.
Sep 04, 2009 | Cameras
Home Depot Switch Doesn't Work. Does anyone know where to get a
Google search Hunter Fan Parts. Should find what you need, and have it in a few days.
Regards, --WoobieDog--
Jul 10, 2009 | Hunter 30216 3-SPEED FLOOR MODEL Air...
My sb 600 fires with the camera but it seems not illuminate
Definately a settings problem. The camera will only syncronize on one specific speed. Youe best bet is to use auto. For manual, you'll have to set the shutter speed at the sync speed.
Flash Sync Speed
  • up to 1/250 X-Sync Speed
  • up to 1/8000 FP High Speed Sync
  • Red-eye reduction
    Red-eye reduction with slow sync
    Rear-curtain sync
    Slow sync
    Front-curtain sync (normal) Flash Sync Modes
  • 1) i-TTL: TTL flash control by 1,005-pixel RGB sensor, built-in flash, SB-800, SB-600, SB-400: i-TTL balanced fill-flash and standard i-TTL flash
    2) AA (Auto Aperture-type) flash: Available with SB-800 used with CPU lens
    3) Non-TTL Auto: Available with Speedlights such as SB-800, 28, 27, and 22S
    4) Range-priority manual flash; available with SB-800 Flash Control
  • Mar 13, 2009 | Nikon Speedlight SB-600 TTL Flash
    What does the speed refer in wireless G 54-Mbps
    It's maximum throughput of wireless network.
    You can find a deep discussion on the subject with any search online or here
    Jan 13, 2009 | Computers & Internet
    952AF/CAN Flash
    I guess you did the basic thing and see if the flash fires when pressing the shutter button.
    I don't know the Rebel itself,but I can suggest a few general things. I will be speculating here for you.
    Make sure that in the setup for the flash, that the curtain is in the correct mode. If I remember right there is something about when the flash will fire. Check this in the instruction manual.
    Also check the flash sync speed range. If the sync speed is out of range for the flash, it will fire at the wrong time. If you want to experiment, try using 1/60 for a start just to see if it works.
    If you call Canon tech support, they will help you.
    Jerry G.
    Apr 17, 2008 | Cameras
    Magnavox 20" tv with vcr and dvd, Model #CT202MW8
    call comcast they should know the correct code its there unit.
    Jan 17, 2008 | Philips Magnavox 20MC4304 20 in....
    Capturing GR-PD1 Hi-Res clips in Final Cut Pro 6
    Check out: http://jvcgr-pd1.blogspot.com/2005/07/dealing-with-pd1s-format-m2t-or-mpeg-2.html Use MPEG Streamclip to convert m2t to a useable file (MPEG).
    Aug 27, 2007 | JVC GR-PD1 Mini DV Digital Camcorder
    Sync Doubling Calendar & Contacts in Outlook 2002
    your t5 is UNSTABLE possibly due syncing to an old username from an old PDA. To correct this: -delete manually the doubles (PDS has a tool but none for outlook) -perform hard reset on your t5 -hotsync - creating a new user name (do not use the old one) -you will be asked to use the same profile name for the outlook Then you should be good to go.
    Sep 12, 2005 | Palm Tungsten T5 - Multilingual Handheld
    Can *ist DL do High-Speed/Wireless Flash?
    According to the manual (page 153), the DL DOES support P-TTL flash, with the built-in or external flash, but only supports high-speed flash with an external flash. What I'm wondering is, what is high-speed sync flash useful for? The only thing I can think of is fill-flash outdoors.
    Sep 08, 2005 | Pentax *ist DL Digital Camera
    Nikon N6006 35mm SLR Camera Logo
    116 people viewed this question
    Top Nikon Photography Experts
    pontelemon
    pontelemon
    michael galang
    Kazim ERGUNEY
    Kazim ERGUNEY
    Are you a Nikon Photography Expert? Answer questions, earn points and help others
