Question about Xantrex Technology Heart Fdm 12 25 Remote Panel 84 2056 01 F/ 10 20 25 30
Can't get my 84-2056-01 to work the inverter. The inverter runs everything in the motorhome just fine but the remote won't light up or do anything at all. I have to do it manually on the inverter. The remote is new and so is the xantrex 3000 watt inverter
    Problem Solver:
  • 17 Answers
This is over a year old, so presumably you solved your problem, but for reference for anyone else reading, the only connection between the inverter/charger and the remote panel is the RJ-11 phone type jack through which the remote panel also draws its power. Just make sure it is firmly seated (until it clicks) on both ends and that the wire is not crimped, cut, or chaffed in between. Otherwise, likely a defective remote panel.
Posted on Sep 27, 2010
I have a 2005 Damon Escaper Motorhome, I just purchased plugs to go from 50 Amp to 30 to 15 Amp to run off of house current, I have a magnum Inverter/Charger after plugging in and following directions...
If the motorhome is happy with a normal mains hookup it should be equally happy being supplied by either a generator or an inverter, as long as they are correctly wired and producing the correct voltage.
The only precaution to take would be to ensure no more appliances draw current than the inverter or generator can comfortably supply.
If the inverter is correctly wired and connected and the load is within limits and nothing is happening, the obvious conclusion is the inverter is not producing current.
I suggest you check the inverter is actually working and producing current and if all is good reexamine how it is connected...
Nov 05, 2017 | Electronics - Others
The output(w) is indicating o.oo and it's indicator light is red .I only have a couple of floor model fans plugged. Should it be showing something and should the light be green?
inverters run on a square voltage unlike normal 110 runs on a round voltage, the only 2 things that won't run on the inverter is fans and electric blankets
Jul 22, 2011 | Cobra 2500w Power Inverter
I have a 1984 class c motorhome on a ford e350 frame. I have no fuel at the carb. I pulled the output line on the electric fuel pump in the rear of the vehicle. ran the pump; no gas. I pulled the input...
I know this might sound odd but try replacing the ignition switch. I have a 86 c class e 350 and could not get the front fuel pump to run for the longest time. After changing everything else, I decided to change the ignition switch, and believe it or not the front pump came on and started working the way it is supposed to.
Jul 07, 2011 | 1983 Ford Econoline
Anything that runs on the battery will not work
ur battery exp.(if it is 3 or 4 year old)
ur inverter is over load
Jul 19, 2010 | Inverter Pure Sine Wave 1500w Inverter
We have an rv with a onan emerld I set generator on board. When we bought the rv (used) the generator did not work at all. We purchased the motherboard for it and it now starts and runs fine but we are not...
Is your generator wired in to an automatic switchover in the motorhome, or do you have external plug in on face of generator, or near it. The power from the generator needs to be attached one way or another to the motorhome. It may be as simple as plugging the cord from motorhome into it, depending on what set-up you have.
May 16, 2010 | 1983 Chevrolet Chevy
I have a Freedom invertor/charger 458 in my motorhome and i can't control the invertor with my remote board. I can push any button and nothing happens/no lights come on. it still charges and inverts. is...
Buy a long phone cord or however long youneed. Run it temporarily to the remote board and the invertor. Make sure powrr is off during this stage.If this doesn't work the solution is probaly going tobe much tougher. See manual.
Here is the owner's manual.http://www.donrowe.com/user_guides/xantrex/fdm_basic_remote.pdf
Feb 21, 2010 | Xantrex Technology DR3624 Inverter/Charger
Inverter will not shut down. I turn off the remote switch in my motorhome or the master switch or the switch on the inverter and it remains on. This will discharge my batteries won't it?
depends on the serial # of your inverter.... the inverter switch on the machine should be turned off and controlled by your remote. If the switch is on at the machine, the remote won't control that part of it.
Jul 14, 2009 | Xantrex Technology Heart Freedom 20 12...
I have a Dometic fridg in my 2005 motorhome and when I start my f
You need to unpush the gas button on the front control. If the gas button is pushed in, then it is trying to run on gas and with the tank empty, it is unable to light. That is why the check light is coming on. If you turn the gas side off and have it on auto, it should switch to the AC side and work fine.
Hope this helps,
Jeff
Jul 05, 2009 | Dometic RM2652 Refrigerator
I have a Class C motorhome. The unit is in storage and when I arrive to check on the motorhome, the alarm is going at low alarm or needs replacing noise. I had the unit checked as well as the motorhome....
hi chuck. the source of the carbon monoxide is outside of your unit. for example other engines running near by sending fumes into your unit and setting off your alarm
Jun 25, 2009 | Safe T Alert Carbon Monoxide Alarm Rv ...
Xantrex Technology Heart Fdm 12 25 Remote Panel 84 2056 01 F/ 10 20 25 30 Logo
233 people viewed this question
Top Xantrex Technology Boating Experts
Craig Butler
Craig Butler
Steve
Steve
Are you a Xantrex Technology Boating Expert? Answer questions, earn points and help others
