Question about Samsung CLP 300 Laser Printer
After replacing the black toner of my Samsung CLP300 colour printer, I am able to print the test page, but when I rpint I get a TOC TOC noise then stops with an error. I seeme that thew front cover does close properly because the cartridge does not go in far enough like the old empty one
    Champion:
  • 220 Answers
Toner is not geniune i take it.
Posted on Jul 01, 2009
I have a HP LJ 4700 printer set up to a network. It will print black but not colour
1. Go to menu set as default.
2. Do color calibration.
3. Print PQ test pages, observe the colors, chk
4. Print demo page. chk
5. Print from different file/system..
Nov 28, 2012 | HP LaserJet 4700 Printer
Samsung clx-3160fn won't print
Usually I've seen that happen when you use generic toners. There are 4 toner clutches down the right side, with the right cover off you can see which clutch is doing the grinding. Many of the generics are overfilled and hard to turn and will make the noise until you loosen them by hand turning them til they loosen up, or just replacing.
Dec 28, 2009 | Samsung CLX 3160fn All-In-One Printer
Samsung, CLP300. The Printer makes a severe
you may check on this issue by opening the back door, pull out paper tray take out the toner block (OPC) and see is there any paper really cought jam.
next examing the noise is from the front or near the back end.
if is from the front. took out the black toner to confirm is the issue from the black toner.
if from the back. Than it will be your DEV Main drive n Fuser gear has already worn out.
Nov 13, 2009 | Samsung CLP 300 Laser Printer
My samsung clp300 prints black in draft (even though everything is set on normal) - colours are okay. Replaced black toner - same problem. help!
This is a problem in the black developer in the imaging unit.
Kindly replace the black developer from authorised service center.
Oct 26, 2009 | Samsung CLP 300 Laser Printer
Black printing faded although toner not low
The black developer is defect, you have to call the service to solve this problem. and install FW Update V1.29.12.35
May 27, 2009 | Samsung CLP 300 Laser Printer
What causes the tapping noise when I print documents?
Could be a faulty toner.
Check if the gears on the tonercartridiges still rotate. Had this problem on a CLP300 a while back : locked gear on the Black toner, causing a "snap-like" sound during printing.
So take out each colour, and see if you can rotate the gear protuding from that cartridige.
Mar 26, 2009 | Samsung CLP 300 Laser Printer
Pring quality on Samsung CLP-300 colour laser
If you the image is faded and your toner supply is good, the problem is the developer blades in the imaging unit. During the normal use of the printer, there is a buildup of toner that sticks on the developer blade. The developer blade meters the amount of toner that gets to the drum that ultimately makes it to the paper. As the toner buildup increases on the blade, less and less toner that gets to the drum cause the image to fade.
To fix this problem you will need to disassemble the imaging unit and clean the blades or buy a new imaging unit. I have clean my blades and I don't have 20000 images it is about 7000 and I have a document to show you if you are handy.
Dec 10, 2008 | Samsung CLP 300 Laser Printer
Samsung CLP-500 cutting off print
The duplexer is bad or needs to be realigned, shake up the cyn color. it mostly likely low.
Dec 06, 2007 | Samsung CLP-500 Laser Printer
Samsung CLP 300 Laser Printer Logo
217 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
