Question about Yamaha RX-V1500 Receiver
RX-V1500 won't turn on...unplugging and plugging
unplugging and plugging back in doesn't work.
power cord is firmly connected
impedance setting won't correct...pushing speakers A and On does nothing
  • severaloffer Jul 01, 2009
    thanks, I did check all speaker wires too, nothing touching. It won't even turn on with all wires taken out.
    How do I get to the fuse?
    Not really. No other tips than what was in my trouble shooting section of owners manual...just an extra fee on the way to the repair shop.
  • Yamaha Master
  • 13,433 Answers
Have you checked for a blown fuse inside the receiver? Also This unit has a Protection Circuitry - which may have been activated by a fault. Also Make sure all speaker wire connections and on all speakers are secure and that the wire for each connection does not touch anything other than what its ment to.
Posted on Jul 01, 2009
  • Ekse Jul 01, 2009
    It should have a two year warranty, so unless your outside of warranty, you don't want to take it apart. The fuse is most likely near where you plug in the power to the unit. If you get no life out of the unit at all, and if you don't find a fuse from this unit the problem could be the power board on the unit, Now I don't have a repair / service manual for your unit so I can't check how it is inside.
I have an hp m8425f and the tower won't turn on,
Remove the Power Cord, then press and hold the power button for 30 seconds. After 30 seconds, plug the cord back in and press the power button. If it works, you had a Static Charge Buildup that had to be released.
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.If the above two steps fail, pull the main power plug that comes out of the power supply and plugs into the motherboard. The end that plugs into the motherboard is probably about two inches long, Grab the release latch on it and press it while pulling up to unplug it. Wait 30 seconds then plug it back into the motherboard. Push it back in firmly.
Try turning on the system.
Apr 04, 2012 | HP Computers & Internet
Receiver shutdown
change your power regulator it is leaky and there are some diodes around the regulator change them also check the caps and some of the resistors some also can be faulty.good luck.
Jun 07, 2007 | Yamaha RX-V1500 Receiver
My tower will not power "on" I shut-down the
Remove the power cord.
Locate the 120V / 240 V ac selector switch. (within 4 inch from the power inlet)
Move it back and forth few time.
Make use it's set to the correct voltage selection.
Reconnect power cord and power up.
===== This AC selector switch can get shifted and set to different position.
Jul 28, 2011 | Acer Aspire™ T180 PC Desktop
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
I cannot get my Lexmark 5600-6500 to turn on
Try to unplug the power adapter from the printer.
Then unplug the power cord from the power outlet. Wait at least 10 seconds before re-plugging the power cord into the power outlet in the wall (bypass any power strip) and the power adapter into the printer. This will give enough time for the printer to reset itself. If printer won't automatically turn on, press the power button. If that doesn't help, please contact Lexmark Technical Support Center for additional assistance.
Jun 28, 2011 | Lexmark X5650 All-in-One InkJet Printer
Orange light 3 flashing
Check your power supply cables Your power supply cables may not be fully secured. Let's unplug and reconnect your power supply
  1. Disconnect the power cord from the back of your console. Unplug the power cord from the wall outlet and the power supply unit.
    Reconnect the power cord to the console. Then plug the power cord back into the wall outlet and the power supply unit
  2. Make sure that all three connections are firmly secured.
  3. Turn your console back on.
Check the light on the power supply. If this solution worked, your power supply light will be green
Dec 29, 2010 | Microsoft Xbox 360 Console
My xbox has a three light red ring
    Reconnect the power cord to the console. Then plug the power cord back into the wall outlet and the power supply unit.
    Check the light on the power supply. If this solution worked, your power supply light will be green and the power button will look like this:
Yamaha RX-V595A tuns off automatically
This was happening to mine also, all of a sudden. This solution came from the owners manual. Sure enough, the impedance selector was stuck in the middle , between 4 and 8 ohms....I also, made sure the speaker wires were not touching each other at the splice. Problem fixed.
B
The unit fails to turn on when
STANDBY/ON is pressed, or set in
the standby mode suddenly soon
after the power has been turned on.
The power cord is not plugged in or the
plug is not completely inserted.
The IMPEDANCE SELECTOR switch
on the rear panel is not fully set to the
upper or lower end.
Firmly plug in the power cord.
Set the switch fully to the upper or
lower end when the unit is in the
standby mode.
Oct 27, 2007 | Yamaha RX-V595A Receiver
No subwofer operation 2year old system
Some systems don't send signal to subwoofer if speakers in SPEAKERS SETUP are set to LARGE, they redirect signal to center and front speakers. Maybe that's problem.
Oct 07, 2007 | Yamaha RX-V1500 Receiver
Yamaha RX-V1500 Shuts down after 2 seconds
This set is getting old and is in the Archives section of the Yamaha consumer guide area. But, you can still download the owners manual if you need one. If it is going into protection mode even when there are no speakers connected OR when the sound level is very, very low or zero it is not good news. Yes, unplugging the line cord will cause the protection system to reset itself. But, if it shuts itself off again soon after rebooting it is a sign of bad grease in the output stages -- in all probability. Let me explain: The audio output transistors are mounted to a large heatsink which keeps them cool during operation. They are electrically isolated from touching the heatsink by an electrical insulating washer. But, in order to keep them cool and allow for good thermal conductivity of the heat generated by the output transistors the washers are treated with a heat conducting grease. Over time this grease will dry out and lose its heat conductivity ability allowing the temperature of the transistors to rise; as the heat goes up they conduct more current and cause the protection system to activate and shut the set down (in order to avoid damage to the set). That is the most common cause of your symptoms. However, there are several other possibilities, but I give this explanation a 90% probability based on my experience.
Dec 12, 2006 | Yamaha RX-V1500 Receiver
Yamaha RX-V1500 Receiver Logo
333 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
