Question about Bose 3·2·1 II System
Bose 3 2 1 dvd flickers and rolls and is in black and white no color
5 Suggested Answers
  • 4 Answers
SOURCE: Can only get black and white images when playing DVD's
i have the same problem with my dvd player soon as you turn it on the screen to the machine is in black and white on the tv its not the dvd its something to do with the tv's ability to switch over to color try connecting it to a dvd recorder that solves the problem most the time the problem is not always the menu stting s inside the machine its self some machines dont have a settings feature to make it in color its most likely something very easy to do the way i mentioned above should help you a little
Posted on Jul 31, 2007
cjackHD
  • 71 Answers
SOURCE: Bose Lifestyle 48 System play's dvd in black & white only
Your s-video cable at the back of your media center is loose. This will cause black and white internal video and is known to fall out or just become loose from minor movement. (it's the nature of s-video cables) This should solve your problem. This is the s-video cable that connects to the VS2 and media center.
If this doesn't solve the problem (I'd be surprised), just reset it by unplugging the DC power cable at the side of the VS-2 for about 30+ seconds and plug it back in..
Posted on May 31, 2009
  • 52 Answers
SOURCE: Bose 321 only plays DVD movies in black and white
This happens because the connections are not pushed in fully. Check the connections are push them fully in, they are very stiff on Bose units.
If that doens't help, try a new cable.
Posted on Jul 08, 2009
smarthome2
  • 1114 Answers
SOURCE: bose lifestyle 48 dvd black and white only
Go to the "Bose" menu screen viewing on your TV (make sure no dvd is in the player) Go to your Video controls and check your output, chances are, if your using the component output your player is set to "S-Video". Should fix the problem. Hope this helps. If it's still not viewing correctly, post a comment and I will help you some more
Posted on Jul 26, 2009
When playing a dvd the color is in b&w only
I have had exactly this problem when changing TVs. Initially I had the sVideo out cable from the Bose with a scart plug on TV end - that worked fine on old TV. On new TV, first Samsung, second SOny, got Black and white video picture. To get it to work I used a component video cable - this is a short svideo cable with a an audio cable at the Bose end. It splits into a 3way R G B cable within 2- 3 inches at Bose end. I then plugged rgb extension cables into this and TV and worked perfectly.
I found the answer to this by errr...... reading the BOse doucumentation I reveived when I bought the Lifestyle system 5 years ago.
Good luck
Peter
May 15, 2010 | Bose Lifestyle 38 System
Dvd playing in black and white
problem is most likly in tv menu settings. display or picture and chang to color
Apr 25, 2010 | Bose 3·2·1 II System
When playing a dvd it black and white no color
what output connection are you using? (svideo can cause this if it's not properly supported on both devices)
What format is the video stream NTFS or PAL? some devices don't like one or the other format. This issue could be linked to your dvd player or your TV so please investigate what I have suggested and post back here if you have no luck :O)
Jan 30, 2010 | Bose Lifestyle 38 System
Bose lifestyle 48 dvd black and white only
Jul 26, 2009 | Bose Lifestyle 48 System
Bose 321 display is only Black and White..all movies too
Could just be the dvds? Or not...
Replace the laser that reads the discs!
Jul 07, 2009 | Bose 3 2 1 GSX System
Black and white picture for DVDs not tv
Make sure you don't have a componet plug in a A\V hole or the other way around.
Mar 15, 2009 | Bose Lifestyle 18 System
Black and White instead of color
Assuming you are using the VS-2 with your system. I have experienced the same problem when I fiddle with equipment. Each time it is due to the S-video plug from the VS-2 cable becoming loose or detached. Make sure every cord is re-inserted into the back of the LS 38.
Dec 07, 2008 | Bose Lifestyle 48 System
Picture rolls on DVD
Maybe your input cable isnt put in all the way from your dvd player to your tv or reiceiver
Nov 03, 2008 | Bose 3 2 1 GSX System
DVD problem - now only plays in black and white
Check the video connections on the back of the Bose unit. I have a Lifestyle 38 and had an issue with video only playing in black & white. Turned out to be a loose connection.
Nov 10, 2007 | Bose 3 2 1 GSX System
Check your settings - video format. It should be NTSC for USA standard. If it is set to European (PAL) it will be in black & white. Hope this helps.
Jul 27, 2007 | Bose 3 2 1 Series I DVD Home Entertainment...
Bose 3·2·1 II System Logo
29 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
