Question about Crayola YCMW2816G 256 MB MP3 Player
Need help when I turn it on it keeps blinking blue and then when I put into my pc I get an erra message i/o some thing.....and it dose not shjow up any where
Re: need help
I ended up returning to crayola and they sent me a new one.
Posted on Jan 03, 2008
Re: need help
Same here. Blinking all the time, will not play.
0 characters
3 Points
My iTouch 4th gen will not turn on anymore. I attempted to jailbreak using greenpois0n and it seems like everything was fine and then when the screen showed the boot logo it just shut off and would not do...
Restore mode is different from DFU mode (CLICK HERE to learn more). You must connect your iPod touch to your PC again and do these steps to put it to DFU mode:
  1. Plug/connect your device to a computer (PC or Mac)
  2. Turn it OFF
  3. Press and hold the POWER and HOME buttons together for EXACTLY 10seconds
  4. Release the POWER button but keep holding the HOME button until the computer beeps indicating that a USB device is recognized.
  5. Re-do the jailbreak.
To make sure that you do things right, I recommend you read my tip:
For more iPhone / iPad / iPod touch tips like jailbreaking and unlocking, CLICK HERE.
Apr 17, 2011 | Apple iPod touch
My H2O man doesn't seem to read the card my songs are loaded on. I converted the files to MP3, but it still doesn't play. The blue light blinks fast then turns red.
If the player blinks blue really fast then red it can only be one of two things.
One: The bracket that goes over the micro SD card is not slide up and locked into place once the card is inserted or
Two: One of the songs loaded on the micro SD card is in the incorrect format. Try playing just the songs that came on the player first. If thoughs work then load 10 new ones on and see if they work. Keep gradually adding songs until the player stops working to help find the problem song.
If you have further questions please call Intova at (808) 837-0074 or e-mail
Dec 25, 2010 | Snap Sights H20 Man MP3 Player
Wont turn on,when i plug to charge in computer ,keeps just having a slow blinking blue light
the inbuilt rechargeable battery life got over.....that is the reason why it works only if u can connect to the ll take power from the usb port and works....
so u r supposed to get the battery replaced at ur nearest service center.....
dont forget to rate me....
good luck....
Apr 15, 2010 | Creative Labs Zen Touch MP3 Player
It turns on and off and now it does not hold data or music
Hey,,,,,Charge it up completely,,,,and then load it up...The computer won't charge it up when you are using it. THEN CHARGE IT UP AGAIN. the battery is the size of a nickel.
Feb 22, 2008 | Coby MP-C758 512 MB MP3 Player
Creative zen vision won't turn on
Q. Zen V is dead
"If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Q. How to reset Zen v +
also try this if above doesnt work
Feb 02, 2008 | Creative Labs ZEN Vision:M Digital Media...
Wont play music and light is blinking help
Has it always done this since you've owned it or is it a recent out of the blue thing you experienced? Try to change the batteries or take them out and put them back in to see if that resets it. Also, try to delete some memory to see if that fixes the problem.
keep us posted on how things go for you. Also,s orry to hear it has taken so long for someone to get back to you.
Keep us posted on how things go. You can also learn more info here directly on the manufacturers website or contact them directly to better assist you.
USB-Stick MP3 Player (1GB) Documentation
Jan 21, 2008 | Coby MP-C883 MP3 Player
Problem with my MP3 Video Player of Innovage Products.
i turn my mp3 player on and i see a blue screen and the blue screen stayes there
Dec 01, 2007 | MP3 & Digital Media Players
MY Sandisk c150 keeps blinking when turned on.
You have probably corrupted it. Plug it back into the computer- reformat if you must and do it properly as you know you should. You may wind up buying another
Aug 14, 2007 | SanDisk Sansa c150 MP3 Player
My mp3 blinks blue
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Jan 13, 2007 | iLO (2 GB) MP3 Player
Crayola YCMW2816G 256 MB MP3 Player Logo
69 people viewed this question
Top Crayola MP3 & Digital Media Players Experts
Gyula Lacz
Are you a Crayola MP3 and Digital Media Player Expert? Answer questions, earn points and help others
