Question about Powershot Tool Company PowerShot 5700KB Forward-Action Heavy-Duty Staple and Nail Gun Kit
PowerShot staple gun model 5700m is jammed
It got stuck when I pressed the trigger, and won't come up. How to unjam it?
There is a silver screw near the back bottom (where you load staples) and you must unscrew it. Completely remove the small bolt and the silver base will pop right out. This base is the track where the loaded staples sit while in the chamber. Just remove the jam and re-install in the reverse order. Works like a charm now.
Posted on Oct 24, 2012
  • Melina Reilly
    Melina Reilly Apr 15, 2017
    Thanks! Although I didn't need to take the base out entirely, I just fished around with a screwdriver and pulled out the jammed staples.
  • 34 Answers
WARNING!! WHATEVER U DO WITH IT, MAKE
SURE POWER IS SHUT OFF!
Posted on Jul 01, 2009
Shredder jammed and will not back up - how do I unjam it?
Carlo, unplug shredder, patiently use pick, scissors etc to remove stuck paper. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Unjam Paper Shredder
How To Fix Paper Shredder Jam Video
How To Clear Jammed Paper Shredder ABC Office
Best Way to Clear Out Jammed Shredder Ask Ozone
Jun 30, 2016 | Shredder Office Equipment & Supplies
How do I unjam a double cocked nerf diatron
1. Make sure that there are two disks loaded in the launcher. They must be pressing against the pressure switch at the top of the chamber. 2. Use a screwdriver to push in the T-shaped switch that would normally be triggered when the priming lever is closed. When both switches are activated, the trigger should be unlocked, allowing you to fire and to release the priming lever.
Feb 15, 2013 | Toys
My new porter cable RN175B nail gun won't discharge a nail
If the trigger is set to single fire, you will need to place the gun against the work then pull trigger as you have done. Try setting the trigger to bump fire and try again. If hear a thump inside the gun, remove the head and check that the head valve in not stuck from lack of lubrication. Easy test, remove the nails, remove trigger pin, remove trigger and manually push trigger firing valve. If the gun fires then suspect faulty trigger or safety arm not lifting enought to activate the trigger valve. Good luck
Nov 21, 2012 | Air Tools & Compressors
Problem with m y dewalt 704 mitre saw type 1, at first the trigger stuck, and now the saw won't run at all, any help would be appreciated.
you need to change switch,when trigger stuck,2 contact on switch weld ,after no contact at all because of wear
Jun 04, 2012 | Dewalt Tools & Hardware - Others
Jammed in Auto, but works fine in reverse. How to unjam?
Continue to alternate between auto and reverse a number of times. Try to shred narrower pieces of paper at opposite ends to see if it can trigger the auto trigger wire. All else fails, carefully take the shredding part apart and you may find a hugh paper jam underneath.
Sep 02, 2010 | Aurora Electronics AS662C Shredder
Film Advance lever stuck
When you press on the shutter release does it "click"? A few hard taps with the end of your finger onto the shutter reelase button may unjam it if it is stuck...
Jun 15, 2009 | Minolta X-370S 35mm SLR Camera
Buzzer will not shut off when load is done
If your dryer also starts without pressing the start switch, then the push to start switch
contacts are stuck in the closed position. Sometimes you can press the button on-off-on-off
quickly to unjam the contacts, otherwise replace switch.
Jan 12, 2009 | Maytag Dryers
My 6 disc changer in my Ford 500 won t Eject or play
well i don't have a 6 cd changer but i have had a few problems like that and all i can tell you is using something to unjam as soon as you hit the eject has been working just fine for me .......hope it helps a bit
Jun 27, 2008 | Car Audio & Video
Powershot Tool Company PowerShot 5700KB Forward-Action Heavy-Duty Staple and Nail Gun Kit Logo
6,298 people viewed this question
Top Powershot Tool Company Tools & Hardware - Others Experts
Marvin
Marvin
john h
Are you a Powershot Tool Company Tool and Hardware - Other Expert? Answer questions, earn points and help others
