Question about GE Refrigerators
The fridge is still running.. its not completly dead .. yet.. but is there a fix to the fridge thats just not cooling well enough.. The freezer just temped at 32 degree F.
  • 585 Answers
The unit is in trouble, but you're right, it's not dead yet. Check the condenser coils, clean them if needed. They must be able to dissipate the heat. Check the condenser fan, must be unobstructed, turn free, a drop of oil may help if it's dying. You may have a failed Defrost system. That failure causes the evaporator coils to ice over, choking off the airflow inside the box. If you shut it down, and train a heatlamp on the rear panel of the freezer (inside) and a small flood occurs, then the defrost is it. After the thaw, you can start the box, and it will cool again until it ices over again. the right answer is to fix the defrost problem in that case. The defrost timer can fail and cause this, if you locate the timer, (usually behind the grille) and advance the center shaft with a screwdriver, slowly until a click and the compressor stops, give it an hour and advance again to restart, you may get a defrost if all else is ok. (replace the timer)
Posted on Jul 01, 2009
2 year old Bosch B22CS is not keeping temp low enough.
Check the condenser on the bottom back side of the fridge if it is plugged off the freezer will not cool enough. If the condenser fan motor is dead then the freezer will never cool down enough. If that doesn't do it then you are looking at a waxed up cap tobe in which care you will need a professional to take care of the problem. Good luck
Sep 08, 2012 | Bosch B22CS30SNS (22 cu ft) Side by Side...
My freezer works but the refrigerator does not cool. At times if here what I think is the compressor running. There is a motor with a fan blade attached that I do not see running, would this have anything...
HI,
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
  • Is the refrigerator completely dead? If so, see “It's stopped completely.”
  • Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
  • Sep 01, 2008 | Refrigerators
    The cooling unit stops running periodically.....long enough to allow food in the freezer to thaw. The fridge light is on, so electricity is getting to the fridge. The previous tenant had dogs, and when we...
    Could be defrost sticking or the compressor not starting...
    Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
    Refrigerator not Cooling or Fridge not Cooling
    How to Defrost Refrigerator Defrost Timer Problem
    Water Running in refrigerator from Freezer
    heatman101
    Sep 26, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
    Freezer not cooling, fan blowing, fridge also not
    If there is no frost , on the inside rear freezer wall ,
    http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter .
    If there is frost , reply back with complete model number .
    Nov 08, 2009 | GE PSS25MGN Side by Side Refrigerator
    Fridge side not getting cool, freezer works great
    is the fan running in the freezer?.
    is ther ice build up on the back wall of the freezer?
    check fridge control, set midway, same with freezer control
    Jul 01, 2009 | KitchenAid (KSRD22FKST) Side by Side...
    Fridge/freezer won't cool completely or freeze
    Things to look for and fix yourself woulf be to clean the coils on the bottom and check the fan motor on bottom, make sure it is ok, Look on back of the freezer walls for frost buildup, a sign the defrost heater is dead.
    May 09, 2009 | Freezers
    Fridge & Freezer not cooling
    You will need to change the complete control pc board.
    Mar 05, 2009 | Samsung RS2630SH Side by Side Refrigerator
    Fridge is not cold and freezer is not cold
    • The compressor
    • The Thermostat
    • The defrost timer
    Jan 10, 2009 | Maytag MSD2454G Side by Side Refrigerator
    Whirpool refrigerator, freezer fine, refrigerator warm
    my suggestion give it up for the dead
    Feb 23, 2008 | Refrigerators
    Refrigerators Logo
    47 people viewed this question
    Top Refrigerators Experts
    Sal De
    Charles T Nevin
    Charles T Nevin
    Randy Justice
